Question about Zanussi FLA1201W Front Load Washer
Fitting of door seal on zanussi electrolux washing machine model aquacycle 1200 xc6 how do you get the the the door seal fitted finding it impossible almost
    President:
  • 1,294 Answers
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
Fit door seal on a zanussi washer
This is not easy and there is a real knack to it. You will find it easier to have a second person helping. One holds the spring in position at the top and the other at the bottom and roll the spring over your hands into the slot
diug
Dec 04, 2014 | Zanussi Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Jan 09, 2010 | Electrolux Washing Machines
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200 XC6 WASHING MACHINE FX1265W TO ENABLE ME TO IDENTIFY THE DIFFERENT PROGRAMME SYMBOLS THE PRODUCT NO.IS 91479270300 TYPE F6857648 CAN YOU HELP
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Nov 29, 2009 | Zanussi Washing Machines
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
May 24, 2006 | Electrolux EW1200i Front Load Washer /...
Zanussi FLA1201W Front Load Washer Logo
1,939 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
