Question about Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower
Troy Bilt 50" zero turn moves forward real slow
Zero turn will not move forward as fast as before when it was new, when going up hill it barely can make it up the hill
5 Suggested Answers
  • 3074 Answers
SOURCE: my troy bilt mustang XP is billowing white smoke
check your belts, the drive belt is off or broken, it runs to the back on above the deck belt. Good Luck Tim
Posted on Apr 18, 2011
rycgl
  • 1545 Answers
SOURCE: troy-bilt model 13AN77TG766 wont go
The manual probably won't be of much help with this problem. Your transaxle may have seized up or failed due to the introduction of water into it. A lot of riders have had this problem, especially the ones with the DANA manufactured transaxle. I hope this is not your problem, and that the problem is in your shifter linkage between the lever and the transmission.
I am continuing to look for the manual. In the meanwhile, here is your complete machine with All parts, diagrams, breakdowns and part costs included. Hope this helps. It is sometimes tough to locate manuals as you have found.
http://www.partstree.com/parts/?lc=Troy-Bilt&mn=13AN77TG766+Pony+%282006%29
Posted on May 21, 2011
  • 122 Answers
SOURCE: How do I replace the
Here's the diagram for that mower, I'm assuming the deck belt broke : http://www.partstree.com/parts/?lc=troy_bilt&mn=17AA5ABP766+RZT+50+%282006%29&dn=769021650003
Belt is 134" x1/2" Troy-Bilt# 954-04044A
Posted on Jul 19, 2011
cardenderek
  • 783 Answers
SOURCE: I own a 42" Troy Bilt zero turn. The PTO switch
What the problem is (im not sure if they are called this) but the deck pulley brakes are worn out.
Basically if you look under the rider frame side (on top of the deck). There are on each side for each spindle pulley a flat metal tab. On the underside of that is just like a brake on your car. So when you raise the deck the pulley brakes hit the top of the pulleys and stop them from spinning. Which cause the blades to stop spinnign. There are probably turning at 10% of there normal speed. If that sound like what its doing check the brakes.
They are a replaceable part. Sorry I just cant remember exactly what they are called. Over the years they just wear out like a set of brake pads on your car. And the mower cuts and just work fine. Thats where I would start. When they wear out, the friction material is gone. Best Reguards, Premium FixYa Support
Posted on Jul 27, 2011
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Left wheel has lost 75% forward/backward power.
fluid level but if its that new it should have a warr
Apr 26, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Why is my troy-bilt mustang 50 zero turn lawn tractor is smoking and burning oil?
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
Aug 04, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower Logo
433 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
