Question about Sharp Audio Players & Recorders
Drivers sharp hr-mb3s mp3 player - Sharp Audio Players & Recorders
Sharp spc570 -cant change from 24hr military time to 12hr time
You must remove the AAA batteries. It will then reset to 12 hr upon reinstall of the batteries. I tried everything to get the 24 hr to12 hr using the time set buttons but nothing worked.
Aug 24, 2013 | Audio Players & Recorders
My mp3 player won't come on after I plugged it into the computer
push reset (this will not delete your files) then plug back into comp... 4 bout' 1 hr. hope this helps
Apr 02, 2010 | GPX MW149 MP3 Player
Battery doesn't hold a charge - 1 hr play from the start - even thought I have charged up to 5 hours
How old is it ?? Try and charge it over night-- It should operate longer than 1 hr. Maybe bring it back for exchange.. ?
Jan 28, 2010 | SanDisk Sansa Clip MP3 Player
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
Why can'tm I play DVD+R DL/2,2x 8 Hr discs on my SharpDV-RW 250x Recorder
Does your player support the disk type you have???
Minus disks are different to Plus disks in respect to the machines they will work in and the formats you put them on to the disk my only be read by the machine the writes them
Looks like your disk type could be a mismatch,
Check them and let me know thanks
Jul 21, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Setting the time
Go to Settings ---> date and time
Set date format: MM/DD/YY or DD/MM/YY
Set date: Day / Month / Year
Set time format: 12 Hr / 24 Hr
Set time: Hour / Minute / Second
Feb 27, 2008 | Philips GOGEAR SA6045 MP3 Player
HDD ERROR
sounds like a hard drive problem and only the manufactuer mostly handle these repairs as its not worth for the repair centers to buy all the parts and stuff like expensive equipment as they have so many types of these units. Please contact the factory at 1-800-237-4277, 1-800-BE SHARP Good Luck
Apr 29, 2006 | Sharp HR-MB3S (4 GB) MP3 Player
14 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
