Question about Health & Beauty
How do I put my shaver back together after I replaced the blades?
I took my shaver apart to replace the heads and Blades and can't remember how it was together
  • 1 more comment
  • Anonymous Apr 03, 2009
    same problem!!!
    need help
  • Anonymous May 05, 2009
    same prob
  • Anonymous May 09, 2009
    same problem!
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Posted on May 21, 2009
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
I took my oster trimmers apart now i dont know how to put them back together can u help me
Unfortunately, Oster does not publish any real maintenance manuals. Basically, if you only took apart the cutting blades and the oscillator, it's not too hard. If you tried to take apart the electric motor, that's a whole different story. If it's just the blade assembly, carefully align the blade assembly with the groove pointing into the trimmer handle and hold the blades together so that they are parallel, not crooked and reinsert the screws. You will see how the blades align, based on the wear marks on the bottom blade guide. If you took apart the oscillating arm, then line up the cam pin with the round hole in the arm, then replace the screws that attach the top blade to the oscillating arm. You may have to push in the tension arm so that you can align the screws with the threaded holes on the handle first. Final step is to screw the bottom blade guide back onto the handle, again align the guide with the blades so that they are parallel and not crooked. The best way to do this is to start threading the screws, then before tightening them all the way, align the blades first. If none of this works, go to this website: http://www.osterstyle.com/CustomerService.aspx and locate an authorized Oster dealer/support center near you. You'll probably have to mail the clippers in to one of the sites.
JB
Feb 25, 2011 | Oster T-Finisher 76059-010 / 76059-030...
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Difficulty positioning the pins for the two blades on shaver head
The blades on the T770 are not supposed to come apart. They are manufactured in such a way that they can not be seperated without breaking the plastic. If yours has come apart, you will need to replace the blade cartridge as there is no way to satifactorily repair them
Feb 23, 2010 | Norelco Micro Action Shaver 4805XL...
I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
Oct 11, 2009 | Vidal Sassoon VSCL828 Hair Trimmer
Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Apr 07, 2009 | Norelco Reflex Shaver 5885XL Electric...
Oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Jul 14, 2008 | Oster 76076-040 Hair Trimmer
Health & Beauty Logo
2,947 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
