Question about Jura Capresso CoffeeTeam Luxe 453 Coffee Maker
I need a wiring diagram for the control panel on a capresso 453
I need to know what colour wires go to which terminals on the control module
2003 Pontiac aztek. What are the three connections for on the ignition module
B+ voltage supply , ground , crankshaft position sensor B input , IC timing control , IC timing signal , low ref. engine speed signal , etc... Do you know what these are ?
Ignition Control Module (ICM) -- C1
Connector Part Information
• 12162261
• 6 Way- F Metri-Pack 150.2 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
TAN/BLK
424
IC Timing Signal
B
WHT
423
IC Timing Control
C-D
Not Used
E
PPL/WHT
430
Low Resolution Engine Speed Signal
F
RED/BLK
453
Low Reference
Ignition Control Module (ICM) -- C2
• 12162184
• 2 Way-F Metri-Pack 150.2 Series Sealed Pull To Seat (BLK)
Pin
Wire Color
Circuit No.
Function
A
YEL
573
CKP Sensor 1 Signal
C
PPL
574
Low Reference
Ignition Control Module (ICM) -- C3
• 12162194
• 2-Way F Metri-Pack 150.2 Series Sealed (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
51
Ground
B
PNK/BLK
239
Ignition 1 Voltage
Nov 07, 2017 | Pontiac Cars & Trucks
I need to know what colour wires connect to the centre plug in the Convenience Unit of my 2002 VW passat 1.9tdi 100 bhp. The part number is 1C0959799A ( 013 ).
HI.
Can you especificate whish connector.
A/C module, Radio. Air bag module...
I have information for that car.
Thank you.
Jul 17, 2008 | Volkswagen Passat Cars & Trucks
How to wire a range rover power seat
There are 4 electric motors under each seat and a 5th inside the back rest. Also under each seat is a module containing the relay and memory module It is possible to run new wires but the job will be much simpler if you have (or can get) a pair of original wiring harnesses to go between the module and the harness behind the centre console (remove ashtray, lighter and storage bin) Spade terminals can be used if the module is missing. Make sure the wiring colours all match.
Of course, this is a simplified explanation. Go to Rovers.net for more detail
Jul 29, 2014 | 2002 Land Rover Range Rover
The air blows but there is no heat. damn thing is only year and half old and samsung will not help
Unplug the dryer. Remove the control panel on the top. Look inside for a sheet of paper with the wiring diagram or service instructions. If you don't find one there, look on the back cover panel. (Every US appliance maker provides this, but I've never looked inside a Samsung dryer so I don't know about their practice.)
If you find the wiring diagram, you can use it to identify the wires going to the thermostats and heating elements. Now you can use an ohmmeter to check which part is open; the wiring colors marked on the diagram will let you find the terminals in the control panel going to the thermostats and heaters so you don't have to take everything apart for diagnosis. Note: in a typical dryer, if you get no heat on Medium, but you get heat on the Low setting, you already know the Medium heat element is burned out. High heat uses both elements.
If you don't find a wiring diagram, you will have to look for the thermostats and heater terminals. Usually there is a thermostat mounted on the door frame at or near the top of the opening to the drum. There will be a second thermostat mounted on the top of the heater pan or box. Usually these are supposed to be closed (you get continuity) when they are closed. The heaters should show some resistance, but should not be open.
If you find an open circuit from the control panel, it doesn't mean the part itself is bad; it could be a problem with the wiring terminal connecting the part. This is often obvious when you see it; the insulation at the terminal will show signs of overheating.
May 30, 2011 | Samsung Dryers
Honeywell s861ou 3009 intermittent pilot module, i just installed this control on my furnace. I have one wire left from my old johnson control. this wire either goes to the draft fan or the burnham logic...
What is the wire on the old control.....what terminal is it on??....When replacing old controls the new ones often have different terminals and sometimes incorporate some terminal internally etc....the Wiring Diagram included should be followed exact....if it's working fineit's likely ok....if you have any doubt have it looked at by an expert
Oct 21, 2009 | Honeywell Electronic Programmable...
Need wiring diagram for a carrier 383kav11048075? im replacing the icm281 control module. gas furnace
There should be a wiring diagram on the panel of the furnace. In the box of the icm 281 is step by step instructions.
Maybe this will help
Take notes on your low voltage wires from the thermostat and condenser. W Y R C G. Write down what color wires go to above terminals.
On your high voltage wiring,
Take the black wire from the transformer and put it on PR-1.
Take the white wire from the transformer and put it on PR-2
Take the black power wire from the panel interlock switch and connect it to L1
Take the white neutral power wire and connect it to L2
Take the black fan motor wire and connect it to HI
Take the red fan motor wire and connect it to LO
Take the white fan motor wire and connect it to COM
Then reconnect your low voltage terminal wires to W Y R C G.
Thats it.
May 03, 2009 | Carrier Heating & Cooling
Replacing a dual burner control switch
First, have you removed the wires from the old switch?
If not, then look on the switch, old or new, and see if there are numbers on the terminals. If so, just move the wires one at a time, terminal number to terminal number.
If you have removed the wires, then you will need to find the wiring diagram, which is most likely found somewhere inside the unit or on the back panel. You should be able to identify the correct wire connection from the wiring diagram.
If you can reply the full model number, I might can find a wiring diagram for it and give you more direction.
Jan 22, 2009 | Kitchen Ranges
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Jun 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Dec 09, 2006 | Hoover HTC243 Top Load Washer
Jura Capresso CoffeeTeam Luxe 453 Coffee Maker Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
