Question about Dehumidifiers
Lost the user manual norko dh 220 dehumidifier
I have Goldstar modle # DH 305y7 it does not run
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 01, 2011 | Goldstar DH304 Dehumidifier
AIRFORCE CLIMATE CONTROL HIGH PERFORMANCE 20 LITRE A DAY DEHUMIDIFIER WDDH-820EAH - Hello can you provide me with basic instructions for this as i have lost my manual. Thanks
Hi and welcome to FixYa, I am Kelly.
Per the model number you provided in your post (WDDH-820EAH) this is your user's Manual:
http://www.orientalpacific.com/backend/files/products/manuals/127/WDH-820EAH%20User%20Manual.pdf
Note the comment about air filter cleaning on the back of the unit every 2 weeks.
Thanks for choosing FixYa,
Kelly
Dec 27, 2010 | Dehumidifiers
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
I need to get a copy of the users manual for the LG 450 EAR .
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Jul 17, 2010 | LG LHD45EL Dehumidifier
What setting should I set my dehumidifier for % humidity when the room temperature is 68
THE LOWER THE % SETTING, THE MORE MOISTURE THE DEHUMIDIFIER WILL REMOVE!!!
I have a Provic dehumidifier mainly to remove damp from walls in my 1900s terraced house ( 3rd DPC failed, another on its way). I've read a lot about the technical side and all I wanted to know was 'do i set it on the highest or lowest % to extract moisture from the walls'. I rang the Managing Director at Provic (his contact details are given on their website) who was very helpful. He advised that the lower the setting, the more damp would be removed from the walls and therefore the air, as the water passes from the wall into the air. My DH ranges from 40% to 70% so he advised me to set it at 40% in the worst affected room to remove as much moisture as possible from the walls. As the moisture is removed, the DH will collect less water and set itself to the correct level anyway. He advised me that when as much water as possible has been removed from this room and the DH % will not drop any lower, to move it to a more central position in the house, such as the hallway to then start setting the rest of the house to the correct humidity level. I set the DH to 40% and left it on overnight closing all doors to the affected room and removing containers of water such as a vase of flowers. When I got up in the morning it had switched itself off as it had already collected 3 litres of water! You do have to be careful not to over dry the air as everything, furniture and electricals, naturally needs moisture, but for a short term, quick drying solution, this level is ok.
Hope this helps!
Jan 01, 2010 | Maytag Dehumidifiers
My dehumidifier keeps cutting out.
Most likely..motor cycles on over load switch..
Nov 04, 2009 | Dehumidifiers
Carlton DH-100 Dehumidifier
CHECK THE MICRO SWITCH LOCATED IN THE UPPER LEFT REAR CORNER WHEN THE COLLECTION BUCKET IS REMOVED. IT MAY BE STUCK OR DEFECTIVE
Mar 18, 2009 | Kenmore 54701 Dehumidifier
Delonghi de 220 dehumidifier tasciugo
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
The above URL will allow you to download instruction manual if a PDF format.
Apr 05, 2008 | Dehumidifiers
Dehumidifiers Logo
204 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
