Question about Treadmill Doctor Proform 650 Cardio Crosstrainer Elliptical Console
Proform 650 cross trainer eleptical display doesn't work
Proform elliptical 825 can't get the display to stop blinking?
If you are not working out on your trainer, the display should flash for a while and than completely stop. But if it continues to flush, please call proform support.
Feb 26, 2014 | Proform Exercise & Fitness
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Apr 04, 2013 | Proform XP 580 Trainer Treadmill
ProForm cross trainer 565. Press start it races for a few seconds then stops. The console keeps going as if everything is still working.
One of the motor controller transistors is shorted.
Phone ICON customer service and order a new controller. It is relatively easy to install. The phone number is on the model number tag..
Feb 05, 2013 | Proform 565 Crosstrainer Treadmill Console
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
When I turn on my proform 650 cross trainer the display shows 8s and flashes brightly one time and then goes blank
1) tRY TO exchange new batteries by news one.
2) Use your calibration software by easy diagnostic and fix it.
3) Tight the flexible cord from key piney vs display board.
4) Tight the connector from display board vs, Main Motor board,
5)aTTACHED THE diagram for sensor reed switch adjusted by 1/8"
6) Test the main motor controller board for 115 Vca,
+5vdc FOR OUTPUT GOING TO DISPLAY BOARD.
7) tEST THE transformer see the tips.
8) Test the power supply for +5Vdc see if there are some componnet like resistor, capacitor, diodes, etc Burns.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness12_26_2011_4_50_52_pm.gifSee the block diagram for easy diagnostic that I did for people like your. Sincerely. Happy New Year G-d bless you.
ernesto cuadra
managua, nicaragua,
Dec 20, 2011 | Proform 650 Crosstrainer Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
I have a 1992 Proform CrossWalk Dual Motion Cross Trainer. Motor still works great. There is rubber covering the roller under the moving piece. It has come off on the right side. Can this be replaced?
Really, I have had my crosswalk for over 20 years. I can't complain. I am passing it on to my son and getting a NEW Proform treadmill. Their longevity has sold me.....
Treadmill Doctor Proform 650 Cardio Crosstrainer Elliptical Console Logo
24 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
