Question about Frigidaire Dryers
Model FDE336RES0 Frigidaire electric dryer clanking noises
We are trying to figure out how to remove the internal drum which is making a clanking noise when it rotates. It sounds like a lot of coins have gotten inside the internal parts and we cannot figure out how to access them. Frigidaire electric dryer model number FDE336RES0. Thanks!
aborcass
  • 2651 Answers
SOURCE: Is there a schematic for
you can remove the lower acees panel ( 3 1/4 screws across the very bottom of unit, this will give you acess, to the insideto better pinpoint where noise is coming from, also across the top of the back of the unit is 3 screws holding down the top assy, by removing this youll be able to access the screws hodling on the inner drum paddles( incase the coin(s)), has gotten between there
Posted on Apr 24, 2008
MNTECH
  • 1543 Answers
SOURCE: Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Posted on Sep 07, 2008
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: my Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
Posted on Jun 09, 2009
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
Frigidaire dryer duzzes when start button pressed or starts but stoppes after a few minutes
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FDE336RES0, buzzes when the start button is pressed. I also see that it starts then stops after a few minutes. I suggest checking the cycle selector and making sure that it is not loose or has not come off. If this is not the case, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Frigidaire Electric Dryer
My Frigidaire dryer makes a loud humming noise and the top and back get very hot to the touch.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
May 20, 2012 | Frigidaire FGR341AC Electric Dryer
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
My maytag dryer,model no.DE303 makes a loude clank-a-d-clank noise as the barrel rotates. Sometimes the sound will change and smooth out, only to get lound again. How do I fix this? It still turns and drys...
This is likely caused by a worn-out drum roller. There are two of these which support the back of the drum and allow it to turn smoothly. Replacing these involves taking the front panels off and removing the drum.
Dec 15, 2011 | Maytag Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
Frigidaire LEQ215EE1 dryer making thumping noise
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Nov 15, 2009 | Dryers
Frigidaire Dryer Drum Making Noise When Turning
that big spring in the back of the drum is your heating element.the part number is 131553900.not sure where to get it up there but marcone appliance parts in st louis missouri might be able to help you out ther phone number is 1-800-482-6022.good luck with your dryer i hope this helps
Sep 07, 2009 | Frigidaire Dryers
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
26 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
