Question about Maxi-Cosi Baby Gear
Cannot open my stroller - Maxi-Cosi Baby Gear
Opening stroller
Please slip the levers off and then straigten the rods and lock the levers again.
May 12, 2010 | Graco DuoGlider - Melbourne Standard...
How do you open the graco duo glide stroller
You need to release the red clip that holds the stroller closed first. Look around for that. Then, pull the parent handle and one of the child trays apart until the stroller locks in the open position.
Sep 19, 2009 | Graco DuoGlider Stroller Safari Sun...
Evenflo aura stroller
there is some red lock on the left side of the stroller just open it
Feb 01, 2009 | Evenflo Aura - Laxford Walnut Stroller
Stroller
ok 1st you have to unfold it.put the red or (any color) nevermind,.kick them into place.i THINK going down. ur welcome!!!!
Jan 25, 2009 | Baby Gear
Opening it
There are two plastic grips on the handlebars of the stroller. Pull both of them upwqards at the same time to either open and lock the stroller, or fold and close the stroller.
Jul 10, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
Can't open graco duoglider
on the side of the stroller the should be a latch lock type of mechanism holding the stroller closed. the hook part of the lock is plastic and the same color of the stroller tubing, but the little part it latches on to should be a bright red color. just locate this lock and release it. you should be able to pull the stroller open. hope this helps. if you're still having trouble, mushroombunny@yahoo.com
Jun 29, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
Stroller
I own two of these strollers- but can't remember what side! haha.. anyways- I think the 'locking mechanisim" is on the right side. On mine- it's a big red "clip".. when the stroller is closed it will be located between two of the metal posts--- when you find it- all you need to do is press down on the side with the grooves- and it will spring the other side up off the clip and as you are holding it- you should be able to open the stroller enough that you can just grab the hand rails and pull it open and everything will 'snap' into place and you're off! Good luck!
Feb 09, 2008 | Evenflo Aura 3s Co Stroller
Baby Gear Logo
24 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
