Question about Ctm Health & Beauty
Ctm hs-686 throttle problem
The speed will accelerate and decelerate with maximum speed set
  • 175 Answers
SOURCE: will higher amp hour batteries damage the motor on my CTM HS-2800
Absolutely not. Higher amphour batts don't put out more voltage, just more voltage longer.
The 2800 takes U-1 gel cell batts that run about 33 amphours...good for about 12-16 miles. You might be able to fit bigger batts in it, but measure first before you buy...gel batts are pricey.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Posted on Sep 07, 2009
Testimonial: "Thank you, found the problem the tech had the battery cables wrong. I redid them and is working now Thanks!"
  • 177 Answers
SOURCE: I need to replace rear wheel tires and bearings
Hi. Probably the best idea is to google the make and model number, and find the nearest agent to order the parts for you.
Good luck. Neil.
Posted on Jun 04, 2010
  • 1739 Answers
SOURCE: I need the armrests for
Available accessories are listed here:
http://www.ctmhomecare.com/Products/index.asp?tStyle=0201&tCategory=Accessorie#PowerChair
I don't see armrests listed for your chair but suggest you make an inquiry of this supplier using their webform to determine if they are available and at what cost, etc.:
http://www.ctmhomecare.com/About_Us_Contact/index.asp
Posted on May 24, 2011
  • 692 Answers
SOURCE: Battery charges, but after unplugging
yep you will need two new U1 batteries Hope this helps you
Posted on Jun 22, 2011
How do I get a wiring diagram for CTM 850
Hi there is a PDF instruction download type in CTM850 mobility scooter schematic. INCLUDES HS-890 or U can get in touch with www.ctmhomecare.com.they might b able to help .good luck
Mar 04, 2016 | Ctm HS 890 4 Wheel Heavy Duty Power...
Where can I download a technical and repair manual for a C T M HS-360 MOBILITY SCOOTER 4 wheel mfg 2003 and parts list?
go google and type in workshop manual for ctm mobility scooter model hs-360
the first page has a pdf version for down load and the site is ctm mobility scooter-ctm home care product .inc.
further down the sites is a pdf version download parts manual as well -- ctm home care hs-360 parts
Oct 24, 2015 | Health & Beauty
Where is the fuse for cruise control on a 2003 envoy
It is HVAC 1fuse #39 in the rear fuse block ,this powers the on/off switch for cruise control ! Fuse Block - Rear Beneath the left rear seat. What engine does it have ? 4.2 L or 5.3 l There is no vacuum involved in the operation of the cruise control ! Your vehicle has electronic throttle control .
Cruise control is a speed control system that maintains a desired vehicle speed under normal driving conditions at vehicle speeds above 40 km/h (25 mph). Steep grades may cause variations in the selected vehicle speeds.
The following are the main components of the Cruise Control System:
The powertrain control module (PCM)
The On/Off switch
The Resume/Accel switch
The Set/Coast switch
The TCC brake switch
The stop lamp switch
The throttle actuator control (TAC) motor
The vehicle speed sensor
Cruise Control Engaged
The cruise control system will engage and adjust the vehicle speed based on the activation of the following cruise control switches:
On/Off
Resume/Accel.
Set/Coast
The cruise control switches are located on the multifunction/turn signal lever.
The powertrain control module (PCM) monitors the signal circuits of the cruise control switches in order to determine when to capture and maintain the selected vehicle speed. The PCM uses the throttle actuator control (TAC) module motor in order to control the vehicle speed. For further information on the TAC System, refer to Throttle Actuator Control (TAC) System Description in Engine Controls - 4.2 L.
Ignition positive voltage is supplied from the 10 ampere HVAC 1 fuse to the cruise control switch via the ignition 3 voltage circuit. When the normally open cruise control On/Off switch is turned On, the switch closes and the PCM detects a high signal voltage on the cruise control on switch signal circuit. When the normally open Set/Coast switch is pressed, the switch closes and the PCM detects a high signal voltage on the cruise control set/coast switch signal circuit. To engage the cruise control system, turn the On/Off switch On and momentarily press the Set/Coast switch. The PCM will confirm that the cruise control enable criteria has been achieved. The PCM will engage the cruise control system and record the selected vehicle speed. The PCM sends a class 2 message to the instrument panel cluster in order to illuminate the cruise control indicator. Pressing the accelerator pedal, while the cruise control system is engaged, will allow the driver to override the cruise control system in order to accelerate the vehicle beyond the current set vehicle speed. When the accelerator pedal is released, the vehicle will decelerate and resume the current set vehicle speed. The driver can also override the current set vehicle speed via the Set/Coast switch and the Resume/Accel switch. When the cruise control system is engaged, pressing and holding the Set/Coast switch will allow the vehicle to decelerate from the current set vehicle speed without deactivating the cruise control system. When the Set/Coast switch is released, the PCM will record the vehicle speed and maintain the vehicle speed as the new set vehicle speed. When the cruise control system is engaged, momentarily pressing the Set/Coast switch will allow the vehicle to decelerate at 1.6 km/h (1 mph) increments for each time that the Set/Coast is momentarily pressed, with a minimum vehicle speed of 37 km/h (23 mph). When the normally open Resume/Accel switch is activated, the switch closes and the PCM detects a high signal voltage on the cruise control resume/accel switch signal circuit. Activating and holding the Resume/Accel switch, when the cruise control system is engaged, will allow the vehicle to accelerate to a greater vehicle speed than the current set vehicle speed. When the Resume/Accel switch is released, the PCM will record the vehicle speed and maintain the vehicle speed as the new set vehicle speed. When the cruise control system is engaged, momentarily activating the Resume/Accel switch will allow the vehicle to accelerate at 1.6 km/h (1 mph) increments for each time that the Resume/Accel switch is momentarily activated, with the maximum acceleration total of 16 km/h (10 mph) over the current set vehicle speed . Momentarily activating the Resume/Accel switch, after the cruise control system has been disengaged by pressing the brake pedal, will recall the previous set vehicle speed that is recorded in the PCM.
Sep 11, 2015 | Cars & Trucks
Light is flashing 6 times
Hi,if the controller is a blue finned model called a Rhino, then the following applies...
6 OONAPU Out Of Neutral At Power Up. The throttle was not in the neutral position
when the scooter was turned on. The scooter does not drive.
• Return the throttle to neutral, turn the power off, and back on again.
• Throttle may need to be adjusted (see section 5.1.6).
• Check throttle wiring.
Regards
Rob
www.gewizrepairs.co.uk
And please join me on Facebook https://www.facebook.com/gewizrepairs
May 10, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
Mar 30, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
Hs 360 scooter light flashes 7 times how do i fix the problem
Hi, this is normally because the throttle pot is either not dead centre or related cabling etc to the controller has been damaged. when looking at the throttle lever look at the centre stem, you should see a cross head, now when at rest this should be dead centre to you, if it isn't it means it moved and that's the fault. Now loosing the related holder etc will allow you to centre it again.. Please contact me for more info if required..
Regards
www.gewirepairs.co.uk
Dec 18, 2013 | CTM Homecare CTM HS-360 4-Wheel Power...
Need owners manual for A ctm hs 740 mobility scooter.
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
Jun 14, 2011 | Ctm HS 890 4 Wheel Heavy Duty Power...
Health & Beauty Logo
32 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Oloyede Monsuru
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
