Question about Garden
Tractor loses power after hot - Garden
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
I have a 650 Yard Machine by Briggs and Stratton and I lose transmission power when going up hills. Is there a reservoir or something to adjust to gain transmission power back?
no but you might check two things... the engagement cable and the belt. if both of those appear ok... get use to pushing it uphills
Oct 18, 2014 | Yard Machines Garden
My Cub Cadet, 15 hrs, will not climb my hill when it is hot, it just stalls, no power to rear wheels, does fine when the tractor is cold, could it be the transaxle ?
Is this unit hydrostatic? If its belt driven it sounds like belt is heating up and stretching causing you to lose friction needed to drive. Have you checked belts?
Sep 09, 2013 | Cub Cadet Garden
My 22 hp craftsman riding lawn mower gets really hot after10 to 20 minutes and backfires and loses power
You may have a mouse problem. Check the shroud (motor cover) to see if there is shredded paper or other material under shroud. If the mouse shreddings get in the fins on flywheel it will cause the engine to overheat. Remove shroud and clean underneath.
Sep 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a ariens 936020 sierra 1640h 1998
Carb problem probably or sticky valve
Jul 27, 2013 | Ariens Garden
Woods 6200 series lawn tractor loses power
fuel problem. either the fuel or air filter is plugged or the jet has something in it. or the carb gasket is bad and allowing air in
Sep 12, 2012 | Woods Garden
TRACTOR STARTS BUT LOSES POWER AND QUITS AFTER
Check to see if you have a fuel screen built into the top of the petcock (shut off valve) in the fuel tank. This may require you to drain the tank. Inspect the screen for being clogged. This is a very common problem. I hope this helps.
Jul 09, 2010 | John Deere 4010 Gas & Diesel Tractor...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
