Question about Maytag Refrigerators
MFI2269VEM water dispenser stopped working
When you press the glass against the lever it clicks but it doesn't make any other sound anymore....same when you choose ice. No humming nothing...Do I have to order a new voltage board or is it something else? All the lights still work fine on the Overlay...
  • 10 more comments
  • amckay Apr 22, 2013
    Oh and it is not the Childlock button =) tried that 1st.
  • John Tripp
    John Tripp Apr 22, 2013
    No ice in the cup when you press requesting ice cubes?
    Nope nothing happens.
    And there is lots of ice cubes in the ice holder on the auger.
    Thats what made me think it wasnt the inlet valve, that wouldnt control the auger would it?
    This is what is making the click noise when the chute arm is pressed it slides past the button on this piece....could it be burnt out? My icemaker is still making ice...just nothing when I select water or ice happens when I press on the chute.
    Oh and I cant seem to find a part number for this....blah. Thanks for any advice or help anyone can give!
  • John Tripp
    John Tripp Apr 23, 2013
    Can you test the switch for continuity? I have found replacement micro switches but they come with other components and have a color. Example part number is 13005705 Yes the switch could be defective but not always. The door switch can also cause the water and ice auger to work....JT
  • amckay Apr 25, 2013
    You can't just order the micro switch? I put a multimeter on it and pressed the switch and got nothing so I think this might be the problem.
  • John Tripp
    John Tripp Apr 25, 2013
    The parts breakdown does not offer the switch alone. Sometimes it is possible to find a micro switch alone but I don't know who can provide the switch. You obviously have found the problem so give Repair Clinic a call and ask them if they can match the micro switch for you. 1-800-269-2609 They will be glad to help you if they can, John Tripp
    Thnx for all your help John!
  • John Tripp
    You are welcome! Let me know if and when you should have a question...Thanks John Tripp
  • Maytag Master
  • 4,654 Answers
The valve may still work electrically but not opening mechanically. The part is=> 67006322 Water Inlet Valve
MFI2269VEM water dispenser stopped working - 6ef47470-08d9-4af2-9558-adf9c251ff5d.jpg
This is going to be tricky finding the valve but should be behind the wall inside the back of the fresh food compartment. Item location number 20 in this photo HERE Another source=> 67006322 Water Inlet Valve
I am here if you have any questions, Thanks Sea Breeze
Posted on Apr 22, 2013
  • 18 Answers
SOURCE: Water dispenser is not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
  • 184 Answers
SOURCE: Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Posted on Apr 10, 2008
SOURCE: Whirlpool Gold Ice dispenser problem
i had same exact problem, i search over and over for solution. I even change the auger moter.
here is the solution for this particular problem.....
with the fridge door closed, remove bottom catch tray under ice dispenser revealing two screws, take off screws and slide front trim up to remove, you will have to unplug switch on trim to fully remove, look in top right corner there is black switch the will most likely be loose, this switch is your problem, mine was basically dislodged and the ice dispenser lever was not making contact, i simply zipped tied and siliconed the switch back to its respective place. if yours is making a good connection then the switch its self must be bad, you can test the switch by using the switch from water dispenser side...
i hope this helps
Posted on Oct 01, 2008
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
Water dispenser does not work
Most likely you need a new water valve or water switch. If there is a click when you push a glass against the water dispenser, that is the solenoid opening. If no click it might need replacing. On mine, the water came out slower and slower; replacing the water inlet valve on the back near the bottom fixed it.
Nov 19, 2013 | Kenmore Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My SSH25KFRFWW doesn't dispense ice or water when you press the lever.
Sounds like you soft reset the pcb when you switched it off. Probably just a glitch. Keep an eye on it for a few days, and check everything for the baby is kept properly cool etc. Good luck!
May 15, 2012 | GE Refrigerators
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
MAKING ICE BUT ICE AND WATER DISPENSER QUIT WORKING.
Sounds like a plugged water filter, assuming the water is turned on to the fridge. If you have a manual, refer to the section about water filters. The filter is usually accessible from the front of the fridge at the bottom....requires about a 1/2 turn counter-clockwise. Some units require that the water be turned off first but not all.
If you do not hear a click when activating the dispenser, there could be an issue with the water solenoid (water valve) that opens and closes when you use the water dispenser....agai...check the manual if at all possible.
Apr 17, 2009 | Frigidaire Refrigerators
Wont dispense water
Did you check the pump at the bottom of the fridge ,and also the solenoid. valve to release the water ,does it click when you depress glass against sensor in dispersal area
Dec 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
436 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
