Question about Whirlpool ACP102PS Portable Air Conditioner
How does auto work?
Does the auto setting help with draining?
I have a lancer es 2010 model with cvt auto I left it in drive handbrake on turned it off when I went to leave it wont shift to reverse or park only neutral and drive can you help
Is the battery up to par? Even though you got the key out(bad lock set), You left everything on. Drained the battery to less than 8 volts. Many things work at 8 volts, but many things don't.
Dec 18, 2016 | 2010 Mitsubishi Lancer
Smart auto and normal lights blink after the wash cycle and the unit shuts down
Hello. The error code you're getting is for a drain pump and water level sensor. Check the filter for obstructions such as food, glass, etc. when you "cancel/drain", does the washer in fact, drain? The drain pump very well might have a blockage or obstruction in it causing it to drain too slowly--especially if the drain hose has that notorious one-way valve in it(it's located inside the rubber boot of the drain hose that is clamped onto the drain pump. When the pump is active, there should be 120v at the connector going to the pump. If there is, and the pump is not working, the pump is defective. If there is *not* voltage, then suspect a broken wire or defective main board. I hope I helped you!
Sep 11, 2015 | Samsung DW80F600UTS 24" Stainless Steel...
How can I unfreeze auto adjustment screen on Samsung HDTV 24"
you ll need to go into the tv;s settings under display follow the onscreen instruction and turn the auto function off and set to custom should help
Apr 15, 2014 | Samsung Clothes Washer Drain Pump Assembly...
ATT Blackberry Curve 8310 - new battery drains after 10 hrs - why
is your phone on auto key lock. this helps my phone so that the battery doesnt drain so quickly, ten hours constantly on it is sufficient for a new phone these days
Aug 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Electrical line connected to the drain pump came lose. Reconnect?
The easiest way woud be to go to K/Mart & buy a Crimp&connector set Around $8.00 In the auto section They have instructions on how to do what you want to put a new end on the wires.(in the auto section).Hope this helps Kind Regards Stefan.
Jul 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Auto gearbox service/oil change renault espace 3.0l automatic
if its working leave well alone,its a renault remember,topping up is done via the auto dip stick ,draining is done by slackening off the sump pan
Dec 31, 2008 | 2003 Renault 181
HP48SX Battery drain
I suggest you use rechargeable batteries. They usually drain faster than the alcaline ones anyway.So have 2 sets of rechargeable batteries. Evaluate the number of days a set lasts. Insert the charged batteries before the old ones are thourougly drained.
The life of your batteries in the calculator depends on the usage.
About repairs: I am convinced that it will cost you more to have it fixed than to buy a new HP calculator (HP 49g*'s, HP 50g* 's).
Hope it helps.
Nov 13, 2008 | HP 19BII Calculator
Dehumidifier will not shut off
The auto shut off will work when you have your bucket in, as well when you have met the humidy level which you have chosen. Try changing the setting.
Sgt 48
Jun 04, 2008 | LG DH30 GoldStar Dehumidifier
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Whirlpool ACP102PS Portable Air Conditioner Logo
14 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
