Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
How do I remove the clutch on my Poulan wild thing?
I just want to rerplace the clutch
5 Suggested Answers
  • 132 Answers
SOURCE: Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Posted on Nov 15, 2008
SOURCE: poulan chainsaw wild thing
Remove the spark plug and squirt a little bit of the fuel from the gas tank into the spark plug hole, replace the spark plug and crank it over several times.
If it runs, or tries to run... that tells you that your engine, ignition system and gasoline are good (or atleast good enough to get it started)
Next check your fuel line and the primer ball. Make sure that when you pump the primer ball that you can see it pumping fuel through the fuel lines in ONE direction only. (It's kind of hard to see, you might have to start the test with empty fuel lines).
If that fails, you need a carb kit because that's where the check valves are. (unless your primer ball is cracked, broken, or clogged)
Next check the metering diafram and needle in the carb. If the diafram is hard (not easily flexible) or if the needle valve is stuck shut the engine will not be able to get the fuel that it needs to run.
If the Needle valve is stuck, just clean it and it'll most likely be fine.
If the diaphram is hardened, you need a carb kit.
If all the above is ok and it still doesn't work... check the gasket at the base of the carb to make sure that the posative pressure pulses from the crankcase are able to make it through the little holes into the carb (that's how it pumps fuel into the carb).
That's pretty much all the easy stuff. Keep in mind that a new carb only costs about $28 at most places.
Posted on May 07, 2009
  • 67 Answers
SOURCE: Fuel Mixture for a Poulan Wild Thing
as far as i know it is 1:40, or 3.2 ounce Oil to 1 Gallon unleaded regular fuel
Posted on Jun 06, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan Wild Thing Chainsaw parts locations
Poulan.com - Dealer locator
http://www.poulanpro.com/node4042.aspx
HTH
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: how to install oil pump in poulan wild thing
Watch the film, before you break fins off your flywheel! The clutch is a left handed thread.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Posted on Oct 14, 2009
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My pully was jammed up, so i removed the cover and when i did so the coil popped out, how do you put it back in place
There is no illustration for this. They want you to purchase a new clutch cover less then $25. There are 2 types of 2375LE (Wild Things) listed here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I'd call them
1 (877) 500-7499 Our Call Center is open Monday to Friday 8am-6pm Eastern Time.
Please have your saw within easy reach when you do.
If the new cover arrives tripped Dolfoff explains how to reset it here:
Reset Chain Brake
Please follow this link, cursor down to “Best Solution”, while there click the “Was this helpful? [Yes}” button.
Dolfoff
http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain HTH
Lou
Oct 18, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I just took apart the brake mechanism on my poulin
The only known illustration for a Poulan 2375LE is here:
Poulan.com
It appears they want you to purchase the entire clutch cover. There is no specific detail.
Type 1 pn530054740 item 39 $19.43
Type 2 pn545139903 item 36 $19.43
There are other than 2375 Wild Things.
Go here for additional help identifying your saw. Please have it within easy reach if telephoning.
http://www.ordertree.com/cms/Contact+Us/6.html
HTH
Lou
Oct 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Jun 06, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild thing motor runs but sproket doesn't turn
Hi, The clutch is shot! This is right at the drive sprocket. leave the bar an chain off and they will fix it in seconds. Warranty right?? If not, you will see an arrow on the way to turn to remove. With a screwdriver straight in on inside body of the clutch, give it a very sharp tap with a hammer. It may take a few trys! Sure wish you had told the make! My crystal ball is not working to well because of the rain! LOL Frankster016
Nov 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Insufficient chain oiling
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace.
On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time.
Glad to be of assistance.
Oct 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
320 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
