Computer error code
Application failed to initialize, code 0x800106ba, A problem caused Windows Defender Service to stop.
This warning appears everytime I start my computer
    Sergeant:
  • 270 Answers
It is because of missing some dll files .that are the library files of windows.so you reinstall your OS
Posted on Mar 13, 2009
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Tip
Windows Defender 0x800106ba Service Error on Automatic Startup
Some times even when the Windows Defender service is set to automatic you still might see the Error below and even when you have tried this site http://support.microsoft.com/kb/931849 which tells you to remove the program and then use the windows installer cleanup utility form HERE and start again you still get the same error
This is a method is bit drastic I suggest that first you update manually the definitions from HERE then download my Windows Defender FIX from my Public SKYDRIVE then restart you PC it should now fix the above error it will re-register all the DLLs that are needed to allow the error to go
on May 01, 2010 | Microsoft Windows XP Professional
How do i fix error ox800106ba
Hi Anon,
The 0x800106ba error may occur after Windows Defender is updated due to the computer's inability to update the Windows Defender firewall. It may not have applicable permissions needed for the update, or it may not have the files necessary for updating itself.
The Fix
Set Windows Defender to Automatic - You can set the Windows Defender service to Automatic, Disabled or Manual. Setting it to automatic might solve the problem. Follow these steps:
  1. Click Start > type services in the Search box > click Services in the Programs list.
  2. If you are asked for a Password before you continue, then enter the password > click Continue.
  3. Double-click Windows Defender, and click Automatic in the start-up box > click OK.
Uninstall and reinstall Windows Defender - If the first procedure did not help resolve the problem, try un-installing and then reinstalling Windows Defender. Due to the fact that Windows Defender is a Windows component, we will use AppWiz to un-install it from the computer. Follow these steps:
  1. Press Windows Key + R > type appwiz.cpl > Press Enter
  2. Click Windows Defender > click Remove
  3. Follow the prompts to uninstall Windows Defender
Let me know how you go!
Feb 12, 2015 | Microsoft Windows Defender
Hi - I have an IBM Think Pad T43 and everytime I press the power button, it starts, but before the password screen appears, a warning box appears and states: services.exe - Application Error The...
Hi. You need to reinstal windows and drivers.
But if you have a backup use it. Is helping you to save your private data like a.. photo , music , movie , etc.
If you don`t have a backup.. hm.. try to enter in safe mode . if you can`t enter in safe mode just reinstall clean windows. Cheers. ! [Sorry for my bad EN.]
Jun 12, 2017 | IBM ThinkPad T42p Notebook
Application failed to initialize 0x800106ba
This should fix it:
http://mycomputerdidwhat.blogspot.com/2008/07/0x800106ba-windows-defender-error-in.html
Aug 26, 2009 | Dell Computers & Internet
Application failed initialise properly (0xc0150002)
I am quoting from Microsoft website for your convenience:
SYMPTOMSWhen you start an Office 2003 program on a Microsoft Windows XP Professional-bas... loadTOCNode(1, 'symptoms'); When you start an Office 2003 program on a Microsoft Windows XP Professional-based computer, you may receive the following error message: The application failed to initialize properly (0xc0150002). Click on OK to terminate the application. CAUSEThis behavior may occur if you install Office 2003 and Windows XP Service Pack 1... loadTOCNode(1, 'cause'); This behavior may occur if you install Office 2003 and Windows XP Service Pack 1a (SP1a) on your computer, and do any of the following:
  • You upgrade your Windows XP Home-based computer to Windows XP Professional.
  • You reinstall Windows XP on your computer.
  • You perform a repair of Windows XP on your computer.
In this scenario, when you start an Office 2003 program, you may receive the error message that is described in the "Symptoms" section. RESOLUTIONTo resolve this behavior, after you upgrade your Windows XP Home-based computer... loadTOCNode(1, 'resolution'); To resolve this behavior, after you upgrade your Windows XP Home-based computer to Windows XP Professional, or you perform a reinstall or repair of Windows XP, reinstall Windows XP SP1a on your computer.
After you reinstall the service pack, restart your computer. MORE INFORMATIONFor additional information about how to obtain the latest Windows XP Service Pa... loadTOCNode(1, 'moreinformation'); For additional information about how to obtain the latest Windows XP Service Pack, click the following article number to view the article in the Microsoft Knowledge Base: 322389 (http://support.microsoft.com/kb/322389/EN-US/ ) How to Obtain the Latest Windows XP Service Pack
For additional information about how to install Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 316941 (http://support.microsoft.com/kb/316941/EN-US/ ) HOW TO: Install Windows XP
For additional information about how to reinstall or repair Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 315341 (http://support.microsoft.com/kb/315341/EN-US/ ) How to Perform an In-Place Upgrade (Reinstallation) of Windows XP"
Aug 17, 2009 | Microsoft Office Professional 2007 Full...
We have error message 0x800106ba on laptop
Go to Start, Settings, Control Panel, Add-remove programs, Now Remove Windows Defender. Now goto the Microsoft website and search for Windows Defender Update, choose the first option. Restart your notebook after the installation has completed.
Hope this helps
May 24, 2009 | Toshiba Satellite A305-S6863 Laptop
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
