Question about Yamaha DVD-S520 DVD Player
Yamaha DVD S520
I owned a DVD Player S520 and when I play a DVD, after an hour and a half, there is a message "ERROR" and the DVD stop. When I play an audio CD , sometimes a message "ERROR 57:04 " appears and the CD stop.
  • Andre Pelletier Aug 03, 2007
    I think it's the optical block, for $150.00
    Novelist:
  • 236 Answers
Yes sir, starting to malfunction and needs replacement now. unless you cant ry cleaning it manually maybe it will help a little but sooner or later it will again give you same trouble
Posted on Aug 04, 2008
SOURCE:
I have a 6 cd changer in my 2005 chysler Pacifica that stopped playing. Shows error message no cd.
My experience with CD/DVD players has been, unfortunately, that when the trays stop opening and/or closing, or when error messages start regularly, it's history. Hope yours turns out differently, but I wouldn't count on it. It will cost you as much or more to fix it than to replace it. if you live near a large junkyard you might try to retrieve one there, but the fact that your car is 13 yrs. old will make that tougher.
Jan 17, 2018 | The Audio Players & Recorders
THE CD PLAYER PLAY ONLY FOR HALF HOUR THEN JUST CUT OUT, LIKE A ELCTRIC ERROR SOUND, NO SOUND, BUT THE RADIO AND TAPE PLAY WITH SOUND. CAN YOU HELP PLEASE MARIANA
CD PLAYER OVERHEATING -- NOT MOUNTED RIGHT .. I HAVE SEEN THIS PROBLEM MANY TIMES AND WORSE IN SUMMER OR WHEN THE CAR HEATER TURNED ON THAT SENDS HEAT FROM UNDER THE DASHBOARD TO THE CD PLAYER ......
HAVE SOMEONE TAKE THE UNIT OUT OF THE CAR AND POWER IT UP ON A WORK BENCH. IF IT CAN PLAY FOR HOURS THEN THIS IS THE PROBLEM. IF IT ALSO STOPS PLAYING WHEN OUT OF THE CAR THEN THE LASER NEEDS CHANGING ......
Jun 20, 2011 | Car Audio & Video
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Pixilation when playback of dubbed and homemade DVDs
As mentioned on the Jan12 e-mailed Panasonic - surprise, no response! However on Panasonic's web site drill down to firmware upgrades for DVD machines. There is an upgrade available for the E50P. Straight forward fix, download to computer, expand it and copy to a CD-R. Put CD-R into E50 and recorder will check and update firmware. I did this on the 13th and have recorded two commercial free movies and both have played back perfectly after finalization. Time will tell. Hope this helps. Golferdon
Dec 29, 2007 | Panasonic DMR-E50 DVD Recorder
Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Oct 28, 2007 | Philips DVDR630VR DVD Recorder/VCR
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Yamaha DVD-S520 DVD Player Logo
345 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
