Question about Novatel Wireless Inc Novatel MiFi Liberate AT&T
MIFI liberate won't turn on
Turn on
How to open battery compartment on internet to go mifi?
A mifi is usually about the size of a credit card. One side will feature an on/off button and a logo. Turn it over. Look for a small arrow and press down in the direction the arrow is facing and the battery cover will slide off.
Jul 23, 2014 | Computers & Internet
I forgot my sim number and lock code
Hi Reyton,
Please contact your service provider and provide them the IMEI number of the MIFI device where in turn they should provide you the unlock code of the device.
May 10, 2014 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Freezing on startup
connect to a pc/laptop. in my computer go to properties of the drive and defrag the drive. see if this works for you. it does some times.
Mar 09, 2014 | Novatel Wireless Inc Novatel MiFi Liberate...
I can't get on any other screen other than the home page of my mifi liberate
Typically the carriers require you to sign in on the mifi home page to setup your mifi. Once you have gone through the setup you will then setup a typical wireless connection using the SSID and Password either setup or given to you by AT&T. Does the home page have a sign in or setup area? If so that is where I would start.
Jan 06, 2014 | Novatel Wireless Inc Novatel MiFi Liberate...
After start up a spinning square
follow this chart guide for troubleshooting and fix it. God bless you
see the status light see your owner manual. or download from www.retrevo.com
Nov 05, 2013 | Novatel Wireless Inc Novatel MiFi Liberate...
My mifi only goes to the att page
Mine does the same thing. If you find the solution, please let me know.
Apr 01, 2013 | Novatel Wireless Inc Novatel MiFi Liberate...
Seized knob, won't turn
Get some rust buster and apply it to the valve stem liberally. Work the shaft in and out a bit to loosen the shaft. Let that rust buster sit on there a bit. Good stuff.
Sep 27, 2011 | Amana AKS3040 Gas Cooktop
I need to hook up my sprint mifi card to my laptop, and not shure how to get to the site to do it.
Turn on the card and after it connects to your laptop
Open Internet Explorer and type 192.168.1.1 to access the MiFi 2200 configuration page. Under Login: Type in the login name (Typically the default login = admin) Click Login
Feb 28, 2011 | Computers & Internet
Just got a mifi 2372 and I can't install it. As soon as I plug it into my computer the wifi light goes off and the computer can't detect it. Can u help
The MiFi is not meant to be cabled to your computer while in use. The manual says the cable is only for software updates and charging it when not in use. Just turn it on without the cable and the computer should detect it. Be aware that it takes a long time to boot up (maybe a minute or so) and that even when the little blue light comes on at the side of the device it can still be another 10-15 seconds before the computer will see it.
Dec 04, 2010 | Novatel Wireless MiFi 2352 and 2372...
Lookbook wireless reader manual
I am having a problem get my lookbook hooked up with my wireless service I have verzion wireless.
Nov 29, 2010 | Sharper Image Literati Reader 16375680042...
Novatel Wireless Inc Novatel MiFi Liberate AT&T Logo
215 people viewed this question
Top Novatel Wireless Inc Computers & Internet Experts
David Payne
David Payne
Are you a Novatel Wireless Inc Computer and Internet Expert? Answer questions, earn points and help others
