Question about Simplicity Broadmoor 22/44
Need info on simplicity broadmoor pto clutch removal and reinstall
Clutch fell off need to know what size and thread bolt holds it on
3 Suggested Answers
Tally Girl
  • 1122 Answers
SOURCE: free manual for simplicity serge por 432
another expert has put up the manual on line previously, link is
http://www.cr-ar.com/sw432/sw432%20manual.pdf
check out their response here http://www.fixya.com/support/t2507530-need_manual_simplicity_pro_serger_sw432
Posted on Dec 02, 2011
  • 43020 Answers
SOURCE: how do I find needles for my simplicity easylock 804 its four thread
I think you can find out thru any simplicity retailer.or by reading thru your owners manual.
Posted on Jan 02, 2015
Simplicity Broadmoor mower pto switch goes bad after 10 minutes of operation. Why?
it could be the clutch is going bad causing the switch to go bad prematurely. need to test the clutch to see how much power it is drawing.
Sep 12, 2017 | Garden
How to remove pto clutch from 2180
The best way that I have found to remove the front pulley or electric clutch is by using an impact wrench. It will work very well since there is no good way to place a back up wrench. The light hammering action frees/loosens bolt very easily. Try it gently in the counter clockwise direction for right hand threads, if this fails try the clockwise motion. Some have left hand threads.
Sep 24, 2014 | Cub Cadet Garden
How to change a pto clutch on cub cadet lt1042
remove engine hood and side shrounds front grill the you have the pto exposed loosen up belt by unhooking the deck then get you a good impact gun 3/4 inch find the socket that one put on impact wrench remove the bolt and only does this job with impact wrench unhook the wireing harness from clutch it should slid off if not tap with a hammer to get it off make sure there no more bolts holding it on reinstall in reverse
Aug 31, 2014 | Cub Cadet Garden
How do you remove the center bolt on the pto clutch
The easiest way to remove one is an impact wrench; otherwise, you would block the flywheel of the engine so it won't turn and use a pull bar.
You will need block the flywheel upon installing as you will need to torque the center bolt to about 55 ft lbs and don't forget to burnish in the PTO clutch.
Jul 30, 2014 | John Deere Garden
On a rzt 42. The pto clutch bolt loosens and clutch falls off with use of 10 minutes or less. How do I fix?
The PTO clutch has a bolt that goes through it and into the vertical shaft of the engine. MANY of the PTO clutches have a large spacing washer that goes on before the PTO clutch is slipped onto the shaft. If the washer was lost when the clutch was changed, the bolt might be bottoming out in the shaft rather than tightening on the threads like it should. I'd get a diagram for your model and make sure all parts are in place.
Jun 05, 2014 | Cub Cadet RZT S Series
PTO clutch making a loud clicking noise.
I really need some more info from you...but here are a few things you should check? Since it clicks with or without the belt...it has to be an electrical issue! Check the switch, look for broken wiring, or loose connections. Another thing it might cause this is the battery or the charging system! If there is not enough voltage to hold the clutch engaged or what it is getting is shorting out then that would be your culprit! I hope this helps! "Be Easy!" Neighborsboy
May 04, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Ford ranger fan clutch
There may be a tool, or you jam a metal tool between two metal parts.
check these out:
Removing Stubborn Clutch fan Ranger Forums The Ultimate Ford Ranger...
Fan clutch removal
Apr 11, 2017 | 1993 Ford Ranger SuperCab
Garden tools riding mowers simplicity
They do not make that pto clutch anymore but you can buy a electric pto clutch for around $200.00 -$300.00 You will need to check the shaft size it should be 1" or 1 1/8" I could give you more info but you need to find it your self.
Paulo
good luck
Oct 27, 2009 | Garden
I need to remove the crankshaft so that I can take the timing bel
Ummm, most of them have a standard right hand thread, they use a key so the bolt doesn't have to fight torque, just hold the clutch on, then look inside, they usualy have a coarse thread 5/8 right hand NC cut into the clutch to remove. but I must ask why do you need the clutch removed
if it's slipping or locking up, it's NOT the clutch the compresor's bad.
If the pulley has the wrong belt then go ahead.
Aug 29, 2009 | Heating & Cooling
PTO clutch stop needs replacing 2130 Cub
take cover off flywheel so you can hold it from turning.or use a air compressor on clutch bolt
Jul 20, 2009 | Garden
Simplicity Broadmoor 22/44 Logo
148 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
Pcm2048
wadingriver
wadingriver
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
