Operation code for JCM gold g-556
Can't switch the operating code function off
3 Suggested Answers
SOURCE: had working sky remote in bedroom, now no remote
Have you got a magic eye in the bedroom,if so the little red light should be on,if it is not then you are not getting a signal from the main box.You need to check the 2nd rf output is switched on in the main box.
Posted on Nov 04, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: POwer switch
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix - see this file) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Jan 31, 2010
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
JCM Gold G355
please go to www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jul 10, 2013 | Computers & Internet
Winsheild wiper will not work
The wiper control module is probably at fault ,without test that is just a guess . The wiper/washer switch is a input to the wiper control module. Do you know anything about automotive electronics an electrical systems ?
  • The Wipers are Inoperative
  • Fuse.
  • Wiper motor.
  • Multi-function switch.
  • Circuitry.
  • Wiper control module.
  • GO to Pinpoint Test B .
Voltage drop testing the power an ground circuits for the wiper control module would be a good place to start . Do you know how to test electrical circuits with a volt meter ?
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK FUSE JUNCTION PANEL FUSE 16 (30A)
Fuse 16 (30A)
  • Is the fuse OK?
Yes GO to B2 .
No REPLACE the fuse. TEST the system for normal operation. If the fuse fails again, CHECK for a short to ground. REPAIR as necessary. B2 CHECK FOR VOLTAGE TO THE WIPER CONTROL MODULE - CIRCUIT 65 (DG)
Wiper Control Module C294
Measure the voltage between wiper control module C294-2, circuit 65 (DG), and ground; and between wiper control module C294-11, circuit 65 (DG), and ground.
  • Is the voltage greater than 10 volts?
Yes GO to B3 .
No REPAIR circuit 65 (DG). TEST the system for normal operation. B3 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper control module C294-3, circuit 57 (BK), and ground; and between wiper control module C294-5, circuit 57 (BK), and ground.
  • Are the resistances less than 5 ohms?
Yes GO to B4 .
No REPAIR circuit 57 (BK). TEST the system for normal operation. B4 CHECK THE MULTI-FUNCTION SWITCH
Multi-Function Switch
Check the multi-function switch; refer to Section 211-05 .
  • Is the multi-function switch OK?
Yes GO to B5 .
No REPLACE the multi-function switch; REFER to Section 211-05 . TEST the system for normal operation. B5 CHECK CIRCUIT 993 (BR/W) FOR OPEN Measure the resistance between multi-function switch C269-4, circuit 993 (BR/W), and wiper control module C294-7, circuit 993 (BR/W).
  • Is the resistance less than 5 ohms?
Yes GO to B6 .
No REPAIR circuit 993 (BR/W). TEST the system for normal operation. B6 CHECK CIRCUIT 589 (O) FOR OPEN Measure the resistance between multi-function switch C269-1, circuit 589 (O), and wiper control module C294-1, circuit 589 (O).
Yes GO to B7 .
No REPAIR circuit 589 (O). TEST the system for normal operation. B7 CHECK THE WIPER CONTROL MODULE OUTPUT FOR VOLTAGE
Wiper Motor C152
Turn the multi-function switch to the HI position. Measure the voltage between wiper motor C152-4, circuit 57 (BK), and wiper motor C152-3, circuit 56 (DB/O).
Yes REPLACE the wiper motor; REFER to Motor-Windshield Wiper . TEST the system for normal operation.
No GO to B8 . B8 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper motor C152-4, circuit 57 (BK), and ground.
Yes REPLACE the wiper control module; REFER to Module-Windshield Wiper . TEST the system for normal operation.
Jun 29, 2017 | 2002 Lincoln Town Car
ABS Light comes on, speedometer stops working and locks switch
I will bet the check engine light comes on as well?
Jul 05, 2017 | 2003 GMC Yukon XL
H and F are popping up
Hi, this code if an alert that represents a water pressure issue. There is No water detected entering the machine or, the Pressure switch trip is not detected.
If after 30 seconds the control does not detect water entering the machine the valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Make sure the Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Press PAUSE/CANCEL twice to clear the display.
Mar 25, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Fan running & stops then goes the opposite direction
Your Hampton Bay combo probably was installed incorrectly. A frequent cause of erratic operation is a conflict between the remote control and the wall switch.
Sep 09, 2017 | Hampton Bay 52 In. 5-Blade Fan, Aged...
How to fix fault code E0-F2 on whirlpool gold gas oven?
The E0-F2 could mean one of the following:
1. Shorted keypad - Replace Electronic Range Control/Clock (ERC)/ Keypad
2. Oven temperature is too high - Check or repair the following:
  • Test operation of door lock on self-clean models
  • Test relay contact operation
  • High resistance in oven temperature sensor
Hope that helps!
Nov 07, 2008 | Whirlpool Kitchen Ranges
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
