Need plastic drive gear for Model: SPL-TXC122A
I have a SPL-TXC122a shredder and I need the plastic drive gear Know where to get one?
I tried to get one for my machine but to no avail. So I fixed my gear myself. Go to your local hardware and buy a "Devcon" plastic welder. Not inexpensive.
You have a broken tooth on the plastic gear. Use a very small
drill bit the size of a big paper clip. drill three holes where the tooth broke off ( if part of the gear tooth is still there, file it down smooth.) Cut three pieces off a paper clip and insert them into the holes. Make them extend to below the gear and not to extend above the original tooth. Now you will make a tooth with the plastic
weld. Fill where the broken tooth was and let it set. Also fill where the paper clip extends below the tooth. This will give it more strength. Let it dry and harden. Now with a small file, file it to make it fit to the next tooth so it doesn't make a bump. " if you can before the mix dries, replace the gear and turn by hand the steel gears to make a smooth fit. Wipe any excess mix away. Good luck....
PS. mine is still working after three years....Hint do not try to shred
to many papers at one time. And once in a while put some 3 in one oil on a piece of paper in a sig sag motion and run it thru the machine. This will help to quiet the noise and oil the cutting blade.
Nov 04, 2014 | Office Equipment & Supplies
Lockout key replacement for paper shredder model# SPL-TXC122A
I am not sure what you mean by a LOCK OUT KEY but perhaps this link to the manufactures site might help.
www.fellowes.com/us/en/support/Pages/faqs.aspx Fellowes Support FAQs
Jul 13, 2014 | Staples SPL826X (CrossCut) Shredder
Parts manual for SPL-TXC122A
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Apr 06, 2013 | Staples TXC122ACC Cross-Cut Shredder; 12...
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR WHEEL WERE TO GET PARTS
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Aug 22, 2010 | Staples SPL616X Cross-Cut Shredder
Staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Jun 16, 2009 | Office Equipment & Supplies
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
Jan 07, 2008 | Office Equipment & Supplies
65 people viewed this question
k24674
