Question about Dryers
How to remove lid of kenmore 110-64982301 dryer
How and what do I have to remove to be able to replace a hidden switch lid on a Kenmore 600 washer?
1st, you'll have to remove the top section that has the controls by removing the screws from the back that attach it to the main body of your machine. Then, you should find the screws or other devices that keep your lid attached to the machine, and be able to remove it, gaining access to that "hidden switch".
Oct 19, 2013 | Kenmore 600 7965 Dryer
How do I replace the dryer belt on a kenmore 70 series dryer
remove two phillips screws under lint screen trap door pop lid up... remove two corner screws usualy 5/16 nut driver lift upward and off to the right idler pulley bottom left pat attention to belt routing before taken off relace pulley change belt and repeat steps and reinstall
Jan 31, 2011 | Kenmore Dryers
One of the baffle fins are loose inside my Kenmore HE2 dryer. How can I tighten?
you can lid or remove the lid to gain access to the screws on the drum vanes.turn the drum by hand to get all the screws tight
Apr 21, 2010 | Kenmore Dryers
Where is the heating element in the kenmore dryer
It depends upon the model number.
Most Kenmore dryer elements are accessible after you remove the rear panel of the dryer.
If your dryer does not have a removable rear panel you must open the top lid and remove the front panel.
Jan 16, 2010 | Kenmore Dryers
I have a kenmore elite electric dryer purchased in 2004 and I am just trying to figure out how to lift the top of the dryer so I can replace the safety switch
Good day,
Remove the lint filter. Remove the 2 screws exposed with the filter out.
Insert a thin screw under the lid and pry it up off it's clips which are on each corner, one at a time.
Lift the lid up, but do not go past vertical. Prop it in place to perform the switch change.
Thanks for using FixYa
Jan 09, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer Kenmore
Yes, but check the breaker first. turn off/on to check. Remove the screws at the lint filter. remove fint filter. Use a thin putty knife at thr front between the top and door support to depress the spring clips holding the lid down, one at a time pull each side to disengage clip. Lift lid. The door switch is above the door inside under the lid. ALWAYS UNPLUG BEFORE WORKING ON ELECTRIC APPLIANCES.
Sep 20, 2009 | Kenmore 63942 Dryer
Belt fell off my kenmore dryer,and i cant figure out how to get into cabinet to replace belt any help?
The lid on the dryer needs to be lifted. Open the door and look up at the underside of the lid. You will see several screws. remove them first. Then slide a putty knife between the lid and the sides about 3-4" back from the front of the drier. There are spring clips in this area on either side. You may need to pop the lid up. Do not use a screwdriver as you may crack the porcelain finish. There should be a belt diagram inside.
Sep 14, 2009 | Kenmore Dryers
I need to replace the dryer belt from a Kenmore washer dryer comb
Remove the top lid, then the front panel to access the drum and belt. Unplug the dryer first.
Jun 07, 2009 | Kenmore Dryers
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
KENMORE DRYER PART NO 696891
My dryer keeps breaking the belts for no reason. I am going to take it outside and beat it with a 10 LB sledge hammer and set it on fire!
Sep 27, 2008 | Kenmore 63942 Dryer
Dryers Logo
15 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
