Question about Canon CLC 1120 Color Copier
Canon CLC 1130 Code E 072 0202
After repair(new) all things, Drum, Sheet, starter, and the cleaning brush
i have the error E072 0202.
Can you helpb me?
Thank you
kaiser
  • 4 Answers
The transfer drum cleaner brush
motor (M8) is faulty.
The polishing roller motor (M9) is
faulty.
The motor drive system is
subjected to an overload.
The attraction/transfer locking cam
motor (PM7) is faulty.
HP sensor (PS8) is faulty.
The registration path driver PCB is
faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
Posted on May 06, 2009
    Sniper:
  • 118 Answers
E072 -A fault in the main motors such as the transfer drum motor, etc
Posted on Jun 24, 2009
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
MI get an E072 at the atm, what could the problem be?
E072 refers to the cleaning drum motor transfer.
The transfer drum has a sensor on the inside that allows the internal mechanism turn initial position, from there to retention, transfer, separation and cleaning. This mechanism is easily positioned to the starting position from the service mode> FUNC, BRUSH, HP. If the problem persists, you have to remove the drum and check smooth transfer care to check their points of support to the main axis, sometimes is slowed by a rubber strip side to slip out of place becomes entangled in the shaft and causes this error.
I recommend you check this engine, in some occasions the main door switch when it flamed this problem also gives you disassemble and thoroughly clean your platinum.
May 05, 2011 | Canon CLC 1110 Copier
Error E072
change the transfer corona assy.
Jun 01, 2010 | Canon CLC 1140 Copier
Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
May 06, 2009 | Canon CLC 1000 Color Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
E072 error CLC 800
i need a sub code like e072-002 or 003 and so on because it can be several things generally it has to do with yopur transfer drum any where that macvhine is way outdaTED AND THERE ARE VERY FEW THAT CAN SOLVE YOUR PROBLEM
Jun 04, 2008 | Canon CLC 1120 Color Copier
E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Apr 09, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
817 people viewed this question
old marine
old marine
