Question about John Deere Garden
I have a John Deere zero turn z425 that wont start, changed spark plugs and one spark plug has good spark the other only has a little spark.
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
  • 32 Answers
SOURCE: John Deere F620 zero turn mower
you probably have the belt on wrong, check your manual to see if you have it on right.
Posted on Jun 21, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
Changing hydraulic fluid and filter on John Deere Z425 zero turn mower?
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Mar 27, 2017 | John Deere Garden
JD z425 zero turn mower. Shows error code 52E.
try a new battery after checking old one for voltage
Aug 13, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
Wont run and emits white smoke
Hi Jeremy:
Sounds like there is still diesel in the fuel system.
There will be a plug on the bottom of the carb.
If you unscrew it and allow it to drain, it will flush the carb.
I'd suggest changing the fuel in the tank again.
You may also need to change the spark plug.
You won't have damaged the engine.
Cheers.
Jun 27, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
We have a John Deere Model #303777. We replaced the fuel line, spark plugs. Engine turns but won't start.
It probably needing a good carburetor cleaning.
It test if is a carburetor put a little in the carburetor throat or remove the spark plugs and put a little in each cylinder and replace the plugs and try to start. If starts up and then dies it is your carburetor.
Mar 14, 2015 | John Deere Garden
I have a John Deere Z225 zero turn engine cranks but will not fire spark plug wet with fuel
as plug wet, either flooded, or not sparking, remove plug connect top lead and touch plug to metal, see if it sparks when turned over, if it does, with a good spark, flooding, check choke, if weak spark, check adjustment of points.
Jul 29, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
Why wont the tractor start
Remove spark plug or plugs. May have flooded, cyline may be full of gas,
Jul 03, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Wiring diagram for a z425
Good day my light indicator says my brakes aren't engage but they are but it still wont start is this as simple as an adjustment or what?
Sep 14, 2013 | John Deere Eztrak Special Edition Kit Z425...
How to replace coil pack on John Deere Z425
Concerning a Z425 John Deere mower. When I start the mower it shuts off immediately, when I try it again the motor cranks but will not start. any suggestions?
Sep 06, 2012 | John Deere Garden
Z425 zero turn turns over but won t crank
I would recommend that you check your fuel filter to see if it is dirty/clogged, check you spark plug to see if it is getting fire. Replace either if needed. If you are not getting spark there are only a few things that it could be, either a coil, pick up coil, or magneto.
Mar 15, 2011 | John Deere 48" 65Bushel Zero Turn Tractor...
Garden Logo
82 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
