Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
After a power outage, my Brother printer,
Aftaer a power outage, my Brother printer, MFC-490CW is offline. I have tried going into the control panel and clicking on print offline, to no avail.
Do I need to re-install the printer?
THANK YOU!
Computer is HP Pavilion with Windows Vista
I am a Senior, so please be as simplistic as possible.
  • 32 Answers
First off, make sure that you have turned both the printer and the computer off and then turn them on(cycle the power). When you go to the printer in 'printers' be sure that the printer is not light in color, if it is, then it's failed to come back online or it's broken. When you say, 'I have tried going into the control panel and clicking on print offline', I take you to mean 'print online', because you don't want to print offline, you want it online...
The easiest way to solve this is to move the usb plug going into the computer from the printer from one port to another, this will force the computer to re recognize the printer. I see that this printer has network capability. I am assuming, that the printer is connected via USB and not Ethernet. [USB, rectangle the size of your pinky, but narrow, Ethernet looks like a big phone plug]. If you move the plug from one USB slot to another and you don't hear the hardware connect sound(low tone then high tone), then your printer may be broken. It is possible if it is broken that the Ethernet port still works, but using that is beyond this discussion.
Good luck,
Brett
Posted on Mar 12, 2009
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 04, 2011 | Brother MFC-490cw All-In-One Inkjet...
My brother printer saying offline help me its a mfc 490cw
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
And/Or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
Mar 31, 2011 | Brother HL-2040 Laser Printer
HI! my printer brother mfc-490cw is offline and wont print .what do i have to do to get it on line ? i own a mac . Louie
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 18, 2011 | Brother MFC 490cw Color Inkjet...
My brother MFC-9320CW say's its connected but when I attempt to print, it says Printer is Offline. What should I do?
I have this problem also with my Brother MFC-490CW printer. I find that I have to shut the printer off, then turn it back on to re-establish a connection.
Jan 03, 2011 | Office Equipment & Supplies
Printer Offline and cannot get it back on
have you tried power off then on again, if yes, go to
START> PRINTER AND FAXES> right click your printer which is the brother mfc-490cw and uncheck USE PRINTER OFFLINE. when you right click your printer there, there shoul no check on the selection USE PRINTER OFFLINE. if that doesnt fix it still, check the usb cable or even try replacing it(the cable) or relocate to where is connected (usb port) on your pc.
a fine feedback would suffice
Jun 02, 2010 | Brother MFC 490cw Color Inkjet...
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
Installed software and tested but keep getting "Off line" status
you have lost your printer driver .
delete the original in add and remove section in your control panel and re install it .
this should fix it
Sep 28, 2009 | Brother MFC 490cw Color Inkjet...
My printer somehow has gotten offline. I have
try reinstalling printer then switch it on before u switch on u comp.
Jun 06, 2009 | Brother MFC 490cw Color Inkjet...
Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Apr 07, 2009 | Brother MFC 490cw Color Inkjet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
1,454 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
