Question about Acer Aspire 4720 Notebook
Want to start wi fi connection on my laptop acer 4720Z on bsnl broadband connection ADSL 2+ modem
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    ur bsnl modem would not include WIFI router does it have if yes then we can go fwd other wise get a router of link sys or Dlink u need a wireless card on laptop which is normally incl in laptops and want a wireless Router on the other side to conenct thru wifi pls fwd details if u have both then we can go fwd
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
Dataone broadband siemens adsl c2110 modem driver
Am I correct in asking you whether you are using a bsnl broadband....???? If so you don't need modem drivers. All you have to do is configure a broadband connection from your network connection wizard with your username and password. Good Luck
Jan 08, 2011 | Computers & Internet
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Wi fi on ACER Aspire 4810T connects intermittently
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
Nov 17, 2009 | Acer TravelMate 4062WLMi Notebook
Dna-a211-1-adsl 2-for-bsnl-broadband CD Download
I HAVE A DNA-A211-I BSNL MODEM. I RESET IT CONTINUE 4-5 TIME AND AFTER RESET IN MODEM DSL AND WLAN IS NOT WORKING AND MODEM IS NOT CONNECTED TO MY PC. I USE WINDOWS 7 HOME PREMIUM. RESET BUTTON IS NOT WORKING. SO PLS SOLVE MY PROBLEM.
Oct 21, 2009 | D-Link DSL-300T Modem
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Problem wifi acer 4720Z
Remove on bottom covering Wi-Fi card. Unseat and Re-seat Wi-Fi Card.
Feb 25, 2009 | Acer Aspire One PC Notebook
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Acer Aspire 4720 Notebook Logo
252 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
