Question about Circo Kids Dresser: Chloe & Conner 3 Drawer Dresser - White
Drawer slides are broken
Need to order 2
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
Crisper drawer- plastic slides are broken off. Where can i get a replacement drawer?
Kenmore is a Sears brand. You should be able to find / order parts from Sears or their parent company Kmart. Be sure to have the MODEL number to obtain the correct parts.
Additionally, you may want to compare prices online from other parts providers (linked below). They *may* be cheaper as they may or may not be using OEM parts. The choice of course, is yours.
Appliance Repair and Parts Help New Purchase Info and More
Search Over 2 1 Million Appliance Parts
Regardless of where you purchase parts, provide the correct model number! You can consult the link below to locate your this information.
Where is my Model Number
Mar 10, 2015 | Kenmore Refrigerators
How do I remove the bottom drawer of a frigidaire gallery electric range
That's a great question, friend!
I see you question is labeled under model FGES3065KB. In order to remove the drawer on that specific Frigidaire range you would need to follow these steps:
1. Open the drawer to full position.
2. Locate the latches on both sides of the drawer.
3. Pull up on the left glide latch and push down on the right glide latch.
4. Pull the drawer away from your range.
I hope this information is helpful to you. -Matt
Sep 10, 2014 | Frigidaire FGES3065KB Gallery 30" Slide In...
Catch on drawer broken and need part number
137006900 strike, male
137006200 catch, female
Mar 05, 2014 | Electrolux EPWD15IW
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
The wheels are broke on the drawer and will slide
No, you don't need a new drawer. You need new drawer rollers. They are cheap. Just order them from your local dealer
Apr 16, 2010 | Casio Parts Cash Register PC Desktop
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Need to remove drawer from the Duet drawer pedestal, it won't come out
I just removed the drawers, you need to remove one each 1/4" head sheet metal screw from the end closest tot he drawer front. this will allow you to slide the drawers out and clean the mess undere both the dryer and the washer. repeat steps to reinstall. Takes about 2 min to remove both doors, Hint: a 1/4 socket works better than a wrench.
Jun 23, 2008 | Whirlpool Washing Machines
Circo Kids Dresser: Chloe & Conner 3 Drawer Dresser - White Logo
54 people viewed this question
Top Circo Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Circo Furniture Expert? Answer questions, earn points and help others
