Question about Ricoh Aficio MP1600SPF Copier
Multifunction machine doesn't work
Ricoh Aficio 6000 showing error SC55
I think you mean "SC550"....all codes are 3 digits. If this is correct, it mean that the Fuser web has expired, and needs replacement, then and only then can the code be reset in service Mode. Call a tech.
Posted on Mar 12, 2009
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
My printer multifunction Aficio sp C240sf show the error message sc542
For this model specifically, the following will get you into service mode.
Hit "Clear / Stop" Buttom then "107" then hold down "color print" buttom for some sec then you are in service mode
If that doesn't work, you can also use Clear/Stop,1,0,7, Clear/Start.
Each key should be pressed and held until you hear a beep
Sep 09, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Hy how are u.i hav a problem with ricoh mp c3501 copy machine.its showing error at screen SC582 if any body know about this error how to soulv it so plz help me am waiting.
Mr Aziz, the machine tell you the termistor had to be replaced located at the back of the fuser unit.After replaced it ,you have to reset the maschine in SP mode.....good day
Sep 01, 2013 | Ricoh Aficio MP C3501 Multifunction Color...
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
How to enter SP Mode for Ricoh Aficio sp 3200sf
"Menu" ? "#" ? "1" ? "9" ? "3" ? "4" ? "Menu"
The display shows "Tech Mode> Tech menu"
Press "OK" to enter Tech menu.
Jun 06, 2012 | Ricoh Aficio SP 3200SF Multifunction...
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio MP1600SPF Copier Logo
454 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
