Question about Jet 708664DK/Model JTAS - 10XL30 - 3DK 5HP 3Ph with 30 Deluxe Fence Table and Legs , Tablesaws
Need fence for craftsman model 137.218250 - Jet 708664DK/Model JTAS - 10XL30 - 3DK 5HP 3Ph with 30 Deluxe Fence Table and Legs , Tablesaws
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
Is there an after-market up-grade for the rip-fence on my sears craftsman table saw - model 113.298151 ?
i need a replacement fence for my craftsman model #113.298762 craftsman no longer makes them . the only other replacement , i found was a delta 36t-30 t2 , which also no longer made thanks bill in ohio
Dec 19, 2012 | Craftsman Radial Arm Saw Table Locking...
I have a craftsman table saw.;;;;;;;;Not a power matic. I would like to know how the fence works and how the stops and adjustments work. There is a stop on the right side of the fence that I do not have...
I think you can download a manual for your saw from this link. or this link.
Another site I have had good luck with for these older models is here. Choose the publications/reprints tab at left, then choose craftsman in the manufacturer's link, and then click on machine type to sort the list into table saws. From there you might find a similar vintage manual that has the details you need. Many models have similar parts, and the descriptions of fence operation, etc are somewhat common.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2011 | Powermatic 1660802K Model 66 Special...
I have a crftsman table saw mdl # 137228210 I purchased the saw used. I need a rip fence . the guides are allready there. any help would be appreciated
There's an exploded parts drawing and parts list at the link below. This may be useful to see what the fence is supposed to look like. It's not listed as an assembly, just a surprisingly long list of parts that would cost a fortune - if they were all available. Maybe you can find one on ebay. Barring that, you can always just clamp a board to the table to rip with - the hard part is getting the makeshift fence to be parallel to the blade. To do that you can use an adjustable square and measure from a miter slot in the table to get a quick and straight setup. Good luck.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137228210/0247/0744600/P0104056/00001?blt=06&prst=0&shdMod=137228210#Partslist
Feb 09, 2011 | Craftsman 10" Table Saw
After moving the table saw to a new residence i cant get the rip fence to line up with blade.i tried everything that was in the trouble shooting guide.
I am guessing it must be damaged beyond the adjustments. Are you sure the blade is aligned with the table? If not that could be the problem. I have most rip fences for craftsman belt drive saws available, Ebay 'Hokienpokie" or contact me via email, if you need another fence. Jim
Oct 05, 2009 | Craftsman Saws
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
Jet 708664DK/Model JTAS - 10XL30 - 3DK 5HP 3Ph with 30 Deluxe Fence Table and Legs , Tablesaws Logo
89 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
