Question about Light & Motion Cycling
How do I open my Sigma illux - Light & Motion Cycling
I have sony DSLR A330 camera. I also have a Sigma 28-200 mm lens sitting in a box that has never been open and just wondering if it will fit onto my sony camera. Any help would be most appreciated.
Sigma makes their lenses with a variety of lens mounts. If your lens has a Sony mount then yes, it will fit your a330. If has, say, a Canon mount, then no, it will not fit.
Aug 20, 2013 | Sigma AF 28-200 Lens
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
How do I insert the batteries in my sigma M500 mouse?
there should be a little trap-door underneath the mouse, if not then the top pops open.
Apr 03, 2011 | Sigma Mouse
My sigma 28-200 lens works inside but when outside with the sun behind me it gives err99 Cheers Jon.
If you are useing on a digitel canon it may work inside were it is
darker it needs the iris fully open but outside it need to close down if canot close down it will give a err99 it would need a rechip sigma in the UK can not do this anymore
Aug 15, 2010 | Sigma AF 28-200 Lens
How do you caculate standard form on a casio fx-83es calculator
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Jun 10, 2010 | Casio fx-300ES Calculator
How to calculate the standard deviaition on the casio fx115es
Apr 05, 2010 | Casio FX-115ES Scientific Calculator
Can not open batery port on the sigma M610 mouse
How do I install my sigma wireless mouse on my pc without instructions
Feb 06, 2010 | Computers & Internet
How to do standard deviation
I assume you know the theory. I will only show you the key strokes for 1-Var statistics.
Press the number corresponding to the variable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
Hope it gets you started
Dec 06, 2009 | Casio FX-115ES Scientific Calculator
My sigma 28-200 have problem with shutter problem my canon eos 450 cannot set more than f3.5 bcoz there are error01
All auto-focus lens have some sort of 'chip' inside .. Sigma 'reversed engineered' Canon's chip - however every time Canon brings out a new camera there is a chance the Sigma lens chip won't work (this is why you see lots of Sigma lens on eBay :-) )
IF you can prove you purchased your lens direct from an authorised Sigma dealer, Sigma will update the chip for free .. otherwise they charge about £35 .. you pay postage in both cases ..
Visit the Sigma web site for further info.
Dec 01, 2008 | Sigma AF 28-200 Lens
Cycling Logo
19 people viewed this question
Top Light & Motion Cycling Experts
John Egan
John Egan
Are you a Light & Motion Cycling Expert? Answer questions, earn points and help others
