Question about Home
Hinge adjustment cedo soft close toilet seat cumin
Fixing
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
  • 2976 Answers
SOURCE: slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Posted on Feb 18, 2009
tsolinac
  • 28 Answers
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Posted on Feb 27, 2010
  • 31 Answers
SOURCE: How do I adjust hinges on a soft close toilet seat
it does this get used to it.
Posted on Apr 11, 2010
SOURCE: cedo Rue Toilet Seat Soft Close White
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Posted on May 03, 2010
Hi, I am replacing a rounded BTW toilet seat and the measurements are: between holes=150mm, width=370mm, length=430mm. I bought a Ceso Rue Softclose from B&Q as per this description http://w
I believe the European standard for distance between fixing holes is 155mm +/- 10 mm. I am not familiar with the actual products you are using, but often these holes are slightly oversize. Your seat may fit depending on this, as well as on the actual diameter of the fixing bolts. You have two options - try it or not. If you don't try it I assume you'll return it. If you do try it and it doesn't fit, you'll return it. You might as well try it, because if it fits, you're done! Good luck.
Dec 01, 2014 | Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
Soft close toilet seat
do not think there is a fix...just replace the seat...
Jun 22, 2014 | Home
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
Can you help re fitting cedo rue toilet seat
Had same problem, this website has the instructions:
http://www.haro-sanitary.com/technical_intelligence_ENG_HTML.htm
Dec 08, 2009 | Home
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Nov 29, 2009 | Duravit Home
I have a Toto saftclose toilet seat but it doesnt close softly!!!
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Apr 01, 2009 | Toto Round Maple SoftClose Toilet Seat...
Home Logo
42 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
