Question about Frigidaire FRS26R4A Side by Side Refrigerator
Older type frigidaire 2door refrig..no ice
Water on door works great,
  • 478 Answers
Check ic tray behind the head for ice or water in it. If no check at solenoid remove line and cycle icemaker if it shuts out you have a clogged funnel tube thru backto inside a common problem.
If trays full pull whitte front cover if you see a gear w/ philips head advance till motor is heard, if just a plastic gear make small insulated jumper, place in holes labeled T and U until click is heard. If these don't continue to operate replace the head or valve as diagnosied.
Posted on Mar 12, 2009
ICE MAKER NOT MAKING ICE AND LEAKING
Your ICE MAKER may be blocked in some way [CLEAN water inlet lines &/or replace the in-line FILTER] OR the THERMOSTAT could be faulty [in an older unit]. Check all in-line water pipe connections for leaks AND/OR damage from any rodents you may have had in your home. This is particularly prevalent in tropical areas and when inlet lines are made from any type of nylon/plastic material. ALSO check your DOOR SEALS as this will sometimes cause this type of problem. It is also possible that the INSULATION in your older unit may be breaking down [you will notice moisture/"sweating" on the outer case surfaces which would indicate this type of fault].
Sep 21, 2014 | Frigidaire Refrigerators
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire refrig water/ice dispensor not working
That could be as simple as the door switch or as complex as the dispenser control board. I will need your model number to get the part numbers. When you open the door the switch turns the light on and when you close the door the same switch turns the controls on for the dispenser. Sea Breeze
Aug 22, 2009 | Frigidaire Refrigerators
I can not get water nor ice side by side refrig
Hello...the water valves might be the problem, seeing how you've checked the water line and water flows out. I had the same problem. No ice, no water. The water valve was defective. Hope this helps you out. :)
Feb 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side model:FRS26HF6BW2
Check the trap door where the ice drops through, it might be stuck in the open position, solenoid that operates the door may be bad.
Jan 27, 2009 | Frigidaire FRS26R4A Side by Side...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag side by side Refrig. - Ice maker chute door
problem is in dispenser, check switches and or selenoid.
Jan 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
62 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
