Question about Uniden BT-108 Bluetooth Headset
BT-108 how to pair with iphone 4 - Uniden BT-108 Bluetooth Headset
My iPhone 5 will not pair with a Bluetooth device
First switch off and switch on,both phone and Sena,switch on BT on the phone.Switch on BT on Sena.Give search on both the devices.As soon the BTs are detected give connect.It will work.
Oct 04, 2014 | Apple iPhone Cell Phones
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
My uniden bt108 bluetooth headset would not pair with my new Iphone4. My Iphone 4 couldn`t even recognize my bt108.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 17, 2010 | Uniden BT-108 Bluetooth Headset
I forget passkey of jebra 108 bt bluetuth
Most modern bluetooth headsets use the pin 0000, if older maybe 1234. Other than that I would consult the devices instruction manual under the pairing area.
Rylan
Dec 15, 2010 | Uniden BT-108 Bluetooth Headset
How can I pair up to my iphone?
see if u can find someone to help u with it
Sep 29, 2010 | Uniden BT-108 Bluetooth Headset
How do I get my Uniden BT-109 in discoverable mode ? I have a new cell, and am trying to pair it with the phone , and have no manual?
First, make sure the device is charged and turned off. Hold the power button down until the LED flashes red and blue. The phone will then be in pairing mode.
Mar 16, 2010 | Uniden BT-108 Bluetooth Headset
How do I pair my iphone with bluetooth on my car
i have got a hands free set in my car and i would like ti connect it up with my iphone
Dec 01, 2009 | Apple iPhone Smartphone
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Uniden BT-108 Bluetooth Headset Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
