Question about Garden
My flymo quicksilver 46sd is leaking alot of oil and smoking alot from the exaust
3 Suggested Answers
AUTODOC01
  • 216 Answers
SOURCE: flymo quicksilver 46s keeps cutting out
make sure button not cracked also fuel filter sits in bottom of tank get you a peice of coat hanger and fish it out just pulls off the end clean it good and also double check your carb sometime you can lose a gasket and it will cause similar issues? let me know if any of this helps ? can also tell you how to adjust high speed side of carb if all else fails?
Posted on Aug 29, 2009
Testimonial: "that was very usefull thank you"
  • 74 Answers
SOURCE: what oil do i use for my Flymo self propelled 46SD Q46SD
Most lawn mowers use SAE 30. Look on the dip stick and it should be printed on there.
Posted on Jun 18, 2012
Hi,I have a Briggs and Stratton Quicksilver 46SD, runs eratically and smokes
Hi,first take the old gas out of the mower and reflll with new.Restart mower and let run for two to three mins.....If it's still smoking you have bad piston rings.
Mar 05, 2015 | Garden
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
White Smoke Coming from Engine?
It sounds like you need a good mechanic to fix your oil leaks. It's probably the valve cover gasket leaking oil on the cylinder head and it's running down on the hot exhaust manifold.
Jan 25, 2014 | Mazda Cars & Trucks
What oil do i use for my Flymo self propelled 46SD Q46SD
Jun 18, 2012 | Garden
Loosing oil, no spots or puddles on ground, no smoke from exhaust
A very common issue with the 1.9L engine is oil consumption. You may not see alot of blue smoke out of the exaust but it is very typical for this engine to consume oil without any visible leaks.
Jun 10, 2010 | 2000 Saturn SL
Leaks oil on the exaust.smoke comes up from back
the tapping is probably from low oil level,you need to keep it full untill you repair the oil leak
Dec 28, 2009 | 1995 Honda Accord
Flymo quicksilver 46s keeps cutting out
Aug 29, 2009 | Garden
Mower running rough
This engine may need overhauling,You seem to have either bad valves or rings, or both.
May 13, 2009 | Garden
I have a 1999 saab 9-5 model and i have 195.000 miles on it i went with the 0 weight 30 mobil one synthetic motor oil on my oil change ran it 3,000 miles and just as i was about to change the oil again it...
Sounds like it's time for a compression check. The head or gasket could be blown, and this test will confirm or deny this fact. Your smoke/steam and the oily residue are pretty good clues...accordianman
Jul 28, 2008 | 2004 Saab 9-3
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
