Question about Jabra BT125 Headset
Ringtone how to change the tone you hear during a call from circus music to a regular ring on the Jabra BT125 Headset?? I have a customer who has it and so does his friend? his friend changed his to ring, while his still plays circus music
SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
Posted on May 20, 2008
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Posted on Dec 13, 2008
SOURCE: jabra bt125 broken ear hook
It's kinda cheesy, but a piece of #10 wire fits perfectly into the hole. That's what I'm using now. Neither the original is very comfortable, but they work.
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
Posted on Sep 10, 2009
  • 4 Answers
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
SET A RINGTONE & PLAY MUSIC
u need to change the phone sound ic or change the phone speaker.
Feb 13, 2012 | Samsung B3310 Cell Phone
How to listen music on Jabra BT 125 with samsung GT-C6112
The Jabra headset when connected to phone will only do voice calls.Will have to get a bluetooth headset that will play music.
Oct 20, 2010 | Jabra BT125 Headset
Jabra BT125 connecting code
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
Jan 07, 2010 | Jabra BT125 Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Ipod ready to call people i hear them but they can not hear me, whats the problem????
I've had similar audio issues when my Motorola V310 was low on battery and also when the Jabra BT125 was low on battery. Recharging helps but if not possible, redialing seems to do better.
Aug 14, 2009 | Jabra BT125 Headset
I change my handset now jabra bt125 is not
Password is 0000.
Jul 03, 2009 | Jabra BT125 Headset
Pass key
Pass keys for bluetooth pairings are usually 0000 unless the item is user configurable and the user changes it to improve security. I do not believe that headset is configurable so 0000 should work just fine.
Jun 23, 2009 | Jabra BT125 Headset
Google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
Apr 15, 2009 | Jabra BT125 Headset
Motorola H350 Bluetooth
because certain headsets have their own tone, no matter what tone you have set on your phone, you need to set it up in the options in the bluetooth headset settings in your phone.
Aug 31, 2008 | Motorola Mobility H350 Wireless Headset
Jabra BT125 Headset Logo
54 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
