My modem is being blocked. when i try to connect to the internet i receive this answer.
  • 39 Answers
Is it internal (integrated) or external modem?
Posted on Mar 14, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
How to connect pc to thinkland
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Disconnect ALL cables from the modem and routericon1.png: internet cable, power, (and ethernet). You can leave the computers on, but if this doesn't work , try it with the computers off.
Connect the modem, cableicon1.png, ethernet, and power. modem .
Connect power on router, Wait until router has a connection
then connect ethernet from modem,
then one by one connect the computer ethernet lines to the router.
Feb 07, 2014 | Computers & Internet
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
WEBPAGE DOWNLOAD
There are many reasons that Internet Explorer could be encountering this issue. Some examples are connectivity to your ISP, a firewall blocking your connection, or your networking device not functioning properly. Here are some things that you can try:
Method 1: Run the Network Diagnostics tool in Internet Explorer
1. Start Internet Explorer, and then try to access the Web page that is displaying the error message.
2. On the page that displays an Internet Explorer error message, click the Diagnose Connection Problems link. The Network Diagnostics tool will run. When the tool has finished running, it will report one of the following results:
    • It was unable to find a problem.
    • It has detected a problem. Additionally, the tool will provide guidance about the next steps to take to troubleshoot the problem.
3. Click IP Address, and note the IP Address. You may need it for future troubleshooting.
4. Follow the steps in the Network Diagnostics tool to fix any connection problems.
5. Start Internet Explorer.
If you receive the same error message, go to the next method.
Method 2: Reset the modem or the router
1. Disconnect the cable that connects the computer to the modem.
2. Turn off the modem and the router.
Note: If the modem or the router does not have a power switch, disconnect the power to the modem or to the router.
3. Restart the computer.
4. After your computer has restarted, turn on the modem or the router, connect the cable from the computer to the modem or the router, and restart the computer.
5. Make sure that all network cables are securely connected.
6. Start Internet Explorer.
Method 3: Use the Delete Browsing History feature
If resetting the modem or the router did not resolve the problem, deleting your browsing history might help. Follow these steps to remove your temporary Internet files, history, and form data:
1. Start Internet Explorer.
2. Click the Safety button, and then click Delete Browsing History.
3. Select the check box next to each category of information you want to delete.
4. Select the Preserve Favorites website data check box if you do not want to delete the cookies and files associated with websites in your Favorites list.
5. Click Delete. (This could take awhile if you have a lot of files and history.)
6. Close Internet Explorer, start Internet Explorer again, and then try to access the Web page.
Method 4: Use the Internet Explorer (No Add-ons) mode
1. To do this, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Internet Explorer (No Add-ons).
If this resolves the issue, follow these steps to isolate the browser add-on that is causing the issue:
  1. Click Tools, and then click Internet Options.
  2. Click the Programs tab, and then click Manage add-ons.
  3. Click an add-on in the Name list, and then click Disable.
  4. Repeat step 3 until you identify the add-on that is causing the issue.
Aug 09, 2011 | Microsoft Internet Explorer 8
Internet on-off key: how to use it ? May it be
hi, rmoriconi
pay no attention to people that tells you that that switch turns your wireless on and off..you do not have a wireless modem
all it does is block your incoming and outgoing internet service, its a security feature and thats it
(your modem is not wireless, if it is, its the first wireless modem i have ever seen)...
bill
Jun 23, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Connecting to the internet
can you access internet via Internet explorer? Try a Ethernet cord connection too.
Dec 07, 2009 | Acer Computer AOA150 Notebook
Error code 109144 when try to connect to internet via wii console
Error Code: 109144 There was a problem registering the console to the WiiConnect24 service. What to do:
  • If you have multiple routers and/or modems, try to connect to no more than one router and one modem try connecting from another location.
  • If you are using only one modem or router, something on your network or from your Internet Service Provider is blocking the connection. You may need to contact your service provider for more information.
  • If you do not have the ability to connect from another location (such as a friend's house), please call 1-800-255-3700 so that we may discuss available options.
Feb 01, 2009 | Nintendo Wii Console
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
