Question about HP LaserJet 1600 Printer
Constant Initialization Serviced the printer, it tested okay... then moments later during a print the paper jammed, I cleared the jam and restarted the printer, only now it gets stuck on the ''initializing...'' screen permanently, called HP support and tried the reset procedure from them but this failed... anyone have any ideas??
  • nathan25 Mar 25, 2009
    Hi, thank you very much for your assistance, I managed to sort the problem out by swapping out the board at the back of the printer... seems it went faulty somewhere along the line.
    Problem Solver:
  • 16 Answers
On the main board ic3 and 2 you will see two fuses fu2 and 1 see which one is blown and replace the ic on next to it. it will work. rb..
Posted on Mar 04, 2010
    Genius:
  • 2,120 Answers
I would start by removing all paper trays, optional memory, network card, etc to see if it boots up then.
Posted on Mar 12, 2009
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Printer says paper jam when there is none
The printer may have an optical paper reader near the print head.
If you can, remove any plastic covers and blow out the head area with compressed air.
The optical reader may be located somewhere else also.
They get covered with paper dust and think its a paper jam.
Blow out all areas of printer.
Dec 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Have cleared paper jam, but alarm light remains on. there is no paper jammed anywhere. please advise
1. Close the tray deck properly.
2. Hold the print key for a moment ...approx 5 secs...it will solve the problem or else restart it.
Oct 19, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
try to check it again maybe there is a small piece left inside the printer or you can try to restart your computer and turn off your printer then during the restart process practically the BIOS booting start your printer.
Jun 19, 2009 | Canon PIXMA MP470 All-in-One Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
Continual problem with paper jam
try with other manufacturer's paper, you can try by reinstalling the drivers
if the problem persist then your printer needs to be serviced
May 31, 2008 | HP Photosmart C7280 Printer
Paper jam
I have had this problem, and have became very furiated.
Clear the Jam by removing and paper you see in from the rear access door.
If you are printing something from a PDF website....... make sure to have it still in the printer schedule.... It will still say printer jam..... but have it there regardless if its something you dont want to have to retype into the pdf form........ After that simply restart your computer. It should resume printer as soon as your computer boots up.....
Worked for me..... Hope this helps everyone else whos probably cursing your printer at the moment!!!!
Mar 22, 2008 | HP Deskjet F335 All-In-One InkJet Printer
HP LaserJet 1600 Printer Logo
521 people viewed this question
Ben Johnson
