Question about Canon PIXMA MP780 All-In-One InkJet Printer
Waste ink well
Where is this? I cannot find it.
  • sam3601 Apr 21, 2009
    Do you know how to remove the waste ink well step by step? since the new mp780 cost around $120. the tech will charge may be $100?
    thanks.
  • Canon Master
  • 419 Answers
The waste ink pads are in the base of the printer and are very difficult to reach in the MP780...
Printers like the iP4000 that are not multifunctional are relatively easy to take apart for replacing or cleaning these pads but multifunction printers like the MP780 are very, very difficult because of all the logic boards, electronics and wires that need to be removed to reach the pads.
I would recommend getting the printer serviced at a Canon service center, it's just too big a job for someone without a lot of technical training.
Posted on Mar 13, 2009
When printing coming on the screen "The Ink
When turned on, the printer initializes the cartridge, and perform inkcharge. So there is some ink discharged to waste ink pad. The printer calculates the amount of waste ink, and when the waste inkreaches a certain amount, which approached the waste absorptioncapacity pad, then the printer will stop printing command. Intendedto waste ink does not overflow from the waste pad. To be able to re-use the printer must be reset waste ink counter., and replace thewaste pad. Or it could also extend the exhaust hose to outsidebottle.
Jan 14, 2011 | Canon Office Equipment & Supplies
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
How to reset epson stylus d120 waste ink counter? where to download software for resetting? thanks
You don't want to reset the waste ink counter unless you have removed all of the waste ink. Unless you feel like totally dismantling your printer and hand washing the felt pads that are currently soaked in ink you'll probably want to have it serviced professionally or just replace it. Most times replacement is less expensive. Resetting the waste ink counter without cleaning out the waste ink can, and likely will, result in waste ink eventually overflowing out of the the bottom of your machine. Be cautious.
Jun 09, 2010 | Office Equipment & Supplies
Waste ink error message, now the printer won't print until the waste ink tank is emptied or replaced.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 11, 2010 | Canon PIXMA iP90 Mobile Printer
Full ink absorber
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
How do I clean the waste ink absorber on a cannon ip90
We are not advice to clean WASTE INK ABSORBER.
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
How do I find the waste ink absorber
The waste ink absorber is usually in the right side of the printer where the cartridges reside when the computer is off. To find the waste ink absorber you need to lift the cover of the printer remove the screws or some printer unlock the clip to remove the cover. After you remove the cover in the right side of the printer. The waste ink absorber is in the bottom of the printer head. Some printer you need first to remove the head before you can remove the waste ink absorber. The waste ink absorber is like a foam that we using in the dish washing you can wash and dry also. But before you can remove the waste ink absorber try first to solve the problem by using some guide how to reset the waste ink absorber problem. If you encounter this search in the internet about how to reset the waste ink absorber.
Apr 18, 2008 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
137 people viewed this question
old marine
old marine
