Question about Braun SI6225 Iron
Rowenta dw 9050
Heat lights intermittent
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Jul 29, 2014 | Rowenta DW-8090 Pro Master SEWERS Iron...
Heat goes off and red light blinks
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
Apr 24, 2014 | Rowenta Irons
How to open is 9050 rowenta precision valet to descale
Well this was helpful but also HELLfull! I guess because I have a 9050 !! I took out the screws & could not remove the hose it was attached with 2 clamps & a washer! I put the whole darn thing in my tub ( I have a sprayer in there) and yes tons of sand, black stuff and cloudy water came out. I had to do this 8 times with the hose attached! Awkward & a mess but it did finally come out clear. BTW I did it through the hose & the bottom hole. On the last run through, after my whole bathroom is soaked including me, the hose popped out! I was cracking up! turns out on the 9050 you simply push down on the ribbed hose covering and it releases. This IS NOT in the manual either. But I'm happy my steamer's like new again & live & learn ;o)
Oct 09, 2012 | Rowenta Commercial Garment Steamer - White
We have a Rowenta Model DW 8080 steam iron. Even when the steaming feature is turned off, there is a water leak in the gap between the bottom plate and the upper part of the iron.
I too have this problem. Ihave bought so my of these irons. I wish so meone else could make something that could put the steam out that this do, that would last for more than a year!!!
Nov 18, 2010 | Rowenta Irons
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Iron will not go on until you wiggle cord &ball
Rowenta DZ 9050 steam iron must be sent to Rowentas repair service in your area.
Local Fix shops will not work on them.
They have parts only.
Feb 19, 2009 | Rowenta Irons
Braun SI6225 Iron Logo
16 people viewed this question
Top Braun Irons Experts
Are you a Braun Iron Expert? Answer questions, earn points and help others
