Question about Avaya Corded Phone avaparp18d
Avaya partner key system phone... we are experiencing static on only one phone on the system... any ideas as to where to look for the problem
  • formulacoop May 11, 2010
    Partner phone systems are notorious for developing static on the station ports of the system. If you are comfrotable with moving the plugs around on the phone system and know where your extension plugs into the modules you can check this yourself. Have you tried the previous suggestion of swapping out the phone with a known working phone? If you still have static and it also happens on internally call(station to station) then the port is going bad.
  • May 11, 2010
    Is the static on both ends of a call, or just on receive at that phone? Our Meridian system at work suffers from the static on receive occasionally and it's always a handset or cord issue. If it's at both ends, try another phone.
When you get the static on a call. Dial another intercom number. Do you still have the static? Is it only on 1 line, try another....
As stated earlier, flip flop 2 extensions and see if you still have it....
Posted on Mar 14, 2009
Is there an downloadable users manual? we just installed this phone and do not know how to set date/time.
Here's a link to avaya's site for a Partner ACS users guide. Not knowing which type of partner system you have, this one should get you into the ball park. Theres also programming and installation guides for the different systems there.
http://support.avaya.com/css/P8/documents/100007287
Also, here's how to change the time.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Nov 04, 2010 | Avaya 18D Phone
My customer has a Partner Mail VS 4.0. At times
Never heard that one before, you might try # 306 and see if the return extension is itsself.
Apr 16, 2010 | Comdial Avaya Partner ACS Phone
HOW DO I SET THE DSATE & TIME ON THE AVAYA
enter in "#103"
Jan 20, 2010 | Avaya Corded Phone avaparp18d
Phone static on the partner 18d
Is it on the same line? What about when you call other extensions, is there static?
If it is a line, swap that line and another. If you have static on the same line port, then it is a port problem of the system. If it follows the dialtone, the line from the phone company is the problem.
Jan 14, 2010 | Avaya Partner 18 Eurostyle 18D telephone
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
The partner voice messaging system would be a card that looks like the processor card , It should also have a green sticker on the face of it identifing it as such.
Dec 11, 2009 | Comdial Avaya Partner ACS Phone
USED AVAYA ACS V7 PARTNER MAIL vm SYS ANSWERING ALL CALLS, I CAN'T ACCESS VM SYSTEM
Depending on the type of voicemail you have, That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming2.gif.
Oct 06, 2009 | Comdial Avaya Partner ACS Phone
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
No power
Try unplugging the key system for a minute, the replug. This should reset your system.
Apr 14, 2009 | Avaya Lucent / Partner Phone system with 5...
Static in phones
Static on Partner systems is not too uncommon and more likely as the system ages. These systems use relays (electric switches) to connect to outside lines and extensions. The static is usually from a faulty relay, but sadly these are not really repairable by end users. A power outage is sometimes associated with spikes - short high voltage conditions that occur as the power comes back on. Any vulnerable component may fail at that time. The solution is to replace the bad circuit pack. These are available used - just use your search engine. Prevention can be as easy as installing a good surge and spike protector power strip between the system and the outlet.
Dec 31, 2007 | Avaya Lucent Partner 616 Phone
Avaya Corded Phone avaparp18d Logo
172 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
