Question about Koolatron WC12G Wine Cooler
Wine cooler quit qorking-plugged in and nothing
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
Jan 11, 2015 | Whirlpool 22" Dual Zone 38 Bottle Wine...
I need a wine cooler with more than two zones for cooling. Does anyone know of a multi-zone cooling system that I can purchase?
There are quite a few high-end multi-zone wine coolers. I found you a great 3-zone 143 bottle system. I must warn you, it is very expensive.
http://www.us-appliance.com/ws14300.html
Jul 31, 2012 | Furniture
I plug my 50 bottle cabnet in and nothing happens, I had a power surg at m y house and I beleave that's when it started. Can't say for sure because I don't check on it all the time
It is quite possible an internal fuse on the cooler has open circuite.
Try plugging in a desk lamp into the wall socket. If that works then you will need to get a technician to check your cooler for you
Apr 04, 2011 | VinoTemp (VT60GNV) Wine Cooler
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
Wine cooler quit cooling> modle# NSA30LACG
Did you get this working? Mine too stopped cooling.
Oct 22, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Koolatron WC12G Wine Cooler Logo
Top Koolatron Furniture Experts
ray gallant
John Mangan
John Mangan
Tom Chichester
Are you a Koolatron Furniture Expert? Answer questions, earn points and help others
