Question about Thermos Quick Set Gas Grill 4000
Tank holder for Thermos 4000. Grill
Neen to secure the tank on the axle. How do you attch the support to the frame??
5 Suggested Answers
burzerko
  • 254 Answers
SOURCE: changing propane tank
Ok on the propane tank valve there will be a black assy. connected to the output side of the valve, if this is the black knob you are talking about it might be stuck if this is the case you might take a pair of slip joint pliers and try taking it loose that way looking at the knob from the front with the tank behind you it will turn counter clokwise to loosen it.
Hope this helps Ya
please rate me.
Posted on Jul 20, 2008
SOURCE: Thermos Grill2Go Fire+Ice parts
Try here,
www.grillparts.com/charbroil/grill-2-go.asp
Posted on Nov 10, 2008
SOURCE: Installing the propane tank
Mine was really putsy. I inherited a neighbors on Tues this week. When you do get it in the correct position the tank will sit perfectly upright.(not angled at all) the back of the top part of the tank (the protective wall around the fittings) will be towards the center of grill. the wire rack will not easily slide over the lip(protective wall), but it does slide over tightly. (you'll know if the bracket was installed upside down because it's too low to work upside down) When it slides forcefully over lip the tank is upright and not angled. I had to putz with mine for quite a while, but the tank fits and is snug. Hope this helps,
Terri
Posted on Aug 14, 2009
Testimonial: "Thanks , Excellent information. A+A+A+A+A+"
  • 54 Answers
SOURCE: The flame on my Thermos Grill 2 Go propane grill
Check the orifice, they are the culprit most of the time. Be careful when cleaning the orifice its a small hole and you do not want to enlarge it.
Posted on May 21, 2010
Mount propane tank
The tank has openings in the handle or frame around the valve. These openings should slip over a mounting bracket on the grill frame under the control knob platform. You may have to loosen a thumb screw to loosen a retaining piece that helps secure the tank on the mounting bracket.
Jul 19, 2011 | Weber Genesis Silver A Grill
How do I loosen a propane canister knob
Are you asking about how to loosen the knob on the tank or how to remove the tank from the grill's holder?
If you're trying to turn the tank valve to ON, you turn the knob Counter Clockwise. If you trying to remove the On/Off knob itself, you remove the screw in the center of the knob. Most require a Star Head screw driver of bit to do this. Be sure the tank valve if completely OFF, before attempting this.
To remove the tank from the grill holder, simply lift the holder off the top rim of the tank. It may be snug, so it sill require some force.
Hope this helps you solve the problem.
Mar 15, 2011 | Thermos Gas Grill 4617222
Not sure how to place propane on to grill
There is a location to place the tank on your grill and there is a regulator that screws on to the tank. So tighten the regulator on to the tank and then you turn the knob on top of the tank and your ready to cook.
Aug 10, 2010 | Thermos Grill2Go Fire+Ice
I have full propane, yet a low flame?
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
May 15, 2010 | Thermos Stainless Steel Gas Grill
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
The flame from the burner stays very small, will not give full power, any ideas on what the problem is?
Disconnect tank, hook back up, open slowly everytime you use grill. If this doesn't solve problem, valve on tank is probably stuck and tank will need to be replaced.
Mar 24, 2010 | Thermos Gas Grill 4617222
We just got a new propane tank and connected it and propane is not coming through
Disconnect and reconnect hand tight, open slowly, if this doesn't do the trick than tank valve is bad. Another thing that could be bad is your regulator, but I would start with tank first is grill worked before new tank.
Mar 21, 2010 | Thermos QuickSet 462836203 (LP) Grill
This is for the Thermos Millenium 4000: I need
Ive replaced the gas tank and make sure valve is on tight but the flame is still weak!?
Feb 01, 2010 | Thermos Quick Set Gas Grill 4000
Terri
May 01, 2009 | Thermos Quick Set Gas Grill 4000
Thermos Quick Set Gas Grill 4000 Logo
60 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
