Question about Danby DDR505R Dehumidifier
How do you operate the settings on ddr505r lost manual
I have lost my operation manuel and would like another.
you can search for one on Google ,make,model,manual
Oct 25, 2015 | Dehumidifiers
We have a dandy dehumidifier ddr557he and have lost the manual. How do We get one online
I FOUND SEVERAL PLACES TO GET ANSWERS TO THIS QUESTION(S)
1. I LOGGED INTO DANBY.COM AND THERE IS A FAQ SECTION, YOU CAN DO THIS AS WELL.
2. FOR THE MANUAL I COULD LOCATE IT AT MANUALSDRIVE.COM
THEY HAVE YOUR SPECIFIC MANUAL.
Jan 02, 2015 | Dehumidifiers
The dehumidifier keeps running and not collecting water. registers 75 and turn down lower but no water
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog control
turn the humidity extraction knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 16, 2011 | Danby DDR505R Dehumidifier
I cant figure out how to operate my LG LHD45ELT8 dehumidifier. I lost my instructions and do not understand how to operate
Shaina, the following link is to your Owner's Manual. You can download and print it for future reference.
http://www.appliancefactoryparts.com/content/pdfs/118812-1.pdf
I hope this helped you and thanks for choosing FixYa.
Jul 23, 2011 | LG LHD45EL Dehumidifier
We lost our manual for ours and my husband cant remember the settings is there a place where i can read the settings or a manual i can download?
Unfortunately, Delonghi, for whatever reason, does not post the Owner's Manuals for their Dehumidifiers online. However, if you call Delonghi Customer Support 800-322-3848 they can furnish one to you. Probably by email attachment.
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | DeLonghi Dehumidifiers
No water in the bucket but water coming out at the botton at the back of the unit.thinks for your help.
Drain line and your drain hole for your unit is clogged. Compressed air is the safest and easiest way to get it unclogged.
Jun 08, 2011 | Danby DDR505R Dehumidifier
No water collectiing - can it be my settings?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 02, 2010 | Danby DDR505R Dehumidifier
Unit blows out cold air while on dehumidifier
Liz; Check for a fuse somewhere in the heat circuit. The master breaker in the house panel also
Jul 07, 2009 | Dehumidifiers
Does not collect water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 28, 2009 | Danby DDR505R Dehumidifier
Dehumidifiers Logo
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
