Question about Kenmore Kitchen Ranges
Can a kenmore gas stove be converted to propane
Can a kenmore gas stove model # 3627525190 be converted to a propane gas stove?
  • Anonymous Mar 14, 2014
    power outage now kenmore gas stove will not come back on
  • Kenmore Master
  • 3,361 Answers
Yes.
If you have the owners manual it may tell you the location of the conversion parts that are probably included with the range.
Posted on Mar 12, 2009
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
Is there something available to convert a hardwick propane stove / oven to run on Natural gas?
Should only be a matter of changing the jets, see a gas fitter if they can be changed.
Dec 20, 2015 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I am trying to find out the proper procedure to convert my holiday gas range to propane. The model is GAK10100. I would like to know who makes this stove and if I might get an owners manual
Jul 01, 2010 | Kitchen Ranges
HOW TO CONVERT IT TO GAS PROPANE?
Your propane supplier can re-jet your stove to accomodate propane. Give them a call ... they will probably do it for little or no charge.
Jul 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore gas stove can it be changed to work for propane
Yes, your gas range can be converted to propane. Your owners manual will give you step by step instructions. Since there are many different models, there are different procedures involved to convert to propane. On some models you must change the top burner orifices where other models have adjustable orifices. The oven burner has an adjustable orifice(same with broil burner if there is one). The range regulator must be adjusted to stay open all the time because your propane system has its own regulator.
Mar 21, 2010 | Kenmore Kitchen Ranges
How to convert from natural gas to propane
All stoves in this country come from the factory with orifices designed to use natural gas. To switch over to propane, the orifices have to be changed over. Contact your propane provider and they will obtain the proper orifices for your range. They may even install them for free. good luck.
Feb 18, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
355 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
