Question about GE WBSE3120B Top Load Washer
Ge 9 min light flashing
My washing machine is stuck with the '9 MIN' light flashing. If I press start, it jumps to FILL for a moment, switches back to 9 MIN, and starts agitating without any water in it. I tried leaving it unplugged over night hoping to reset it but got the same result in the morning.
  • Ryan Tensmeyer Apr 22, 2013
    I broke down and had a technician come and fix it for me. It ended up being a loose wire in the panel.
Posted on Apr 22, 2013
docjohn174
  • 943 Answers
SOURCE: GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
  • 3600 Answers
SOURCE: GE Washer keeps getting stuck in drain cycle
When you replace the timer before did you tighten up the connectors? and you can figure out your budget I can't $60.00 for a new timer or $1000.00 for a new one. if it lasted for a few years I could find a use for the money elsewhere. But if it has other probems then by all means replace the machine.
Posted on Aug 06, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Will not start
is there any codes that is flashing
Sep 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Huskee LT 4200. I jumped the battery to get it to start. I mowed for 45 min, turned it off, added gas, starting mowing again for 30 min. Turned it off & now it won't start, turn over or crank. I...
try tapping the starter lightly with a small hammer to rule out a stuck armature. Also make sure all of your connections are tight.
Please explain how you "jumped" it. was it with another battery?
Jun 18, 2013 | Cars & Trucks
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
On my ge answering machine, the CL red light keeps flashing even though there is zero msg. so how do I clear this CL red light flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Nov 02, 2009 | Uniden Cordless Phone
Can't set the ttime
Press and hold the hr button for 3 seconds until the 12:00 starts flashing, then press the hr button again to set the hour. Then, press and hold the min button for 3 seconds until flashing starts - press the min button until minutes set.
-Tha Mp3 Doctor
Mar 08, 2009 | GE 106591 Coffee Maker
Flashing CL light
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day / check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Apr 02, 2008 | Uniden Cordless Phone
GE WBSE3120B Top Load Washer Logo
60 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
