Question about Insignia LCDTV26 26 in. Television
Can not get sound from stero to the tv but can get sound comming from vcr can you help me
    President:
  • 814 Answers
You have to check you input and output sources and coordinate The same input and out puts with you remote controls. For instance output one on the stereo goes to input one on you television and output two goes to input two on you television. The switching should be done on both remotes unless you are using a single output from your stereo to the input on you television. In this way one setting on the television will be fine and all the input switching will be done from the stereo unit. All this information should be in your owners manuals for the products in how to hook up external devises to you television. Hope this helps you with your problem.
Posted on May 10, 2009
Philips Magnavox TV TS 3260 C121
Audio decoder section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 22, 2016 | Philips Magnavox 27MS343S 27" TV
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
When hooking up HDMI why can I not get sound I hooked the HDMI from the cable box to the reciver and from the reciver to the TV I assinged the Hdmi and I get picture on the Tv I also can get sound out of...
I have researched on your issue and found that the Receiver is not capable of processing audio from HDMI input. It will bypass the signals from its HDMI input to HDMI output..
The Receiver has 3 HDMI input and one output. Hence you can use this as a HDMI switch to connect three HDMI devices to single HDMI port on the TV.
In order to get the sound from speakers connected to the Receiver, it is required to make alternate digital or analog audio connection.
You can confirm the information from the manual of the Home Theater System. Please refer page # 36 of the Manual to get the information. I have provided a link where you can download the Manual for the HT System:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/580/580HT5100B.PDF
Jan 15, 2011 | Onkyo HT-S5100 Theater System
I'm connecting my tv to a stereo receiver to get stero sound through the stereo speakers.done this a hundred times with other tv's but can't get this one to work.
how do i hook up my stero to my dynex tv? stero has no hdmi cabl neither does my cd player. i also go through my cable box not high def Thank u for any help
Jan 02, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Vizio tv
Boy, what luck! Unfortunately both those units have IR receivers that are using the same code of which you can't change, so I would put a piece of black tape over the stereo's IR window, the only draw back is you will have to turn it on manually. Try it and see if it helps and let me know.
Apr 27, 2009 | Vizio L37 Television
Stero SAP
Go to tv setup in the tv menu and turn off the SAP.
Sep 02, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Ph601s universal philips remote it controls 6 devices tv vcr dvd cbl sat cd
I have a sharp a philips dvd a hitachi vcr apinoneer sound system
Feb 09, 2008 | Televison & Video
Stero sound comes in and out
What if you tap the side of the set when is doing it only to see if it reacts,if it does the you know you have a loose conection,sometimes you have a separate board for the stereo amp and the speakers conector plugs in ,sometimes in all in the main board and the speaker wires conect to the jack panel,The speaker conector is a good place to start.Be careful.
Sep 20, 2006 | Toshiba 27AF42 27" TV
Insignia LCDTV26 26 in. Television Logo
47 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
