Question about Ovens
Maytag gas oven touch-pad control panel does not work proplerly.
I have a free-standing Maytag gas oven/range. The touch-pad control panel has become very touchy. The ''pad'' no longer allows me to use the oven timer. Also, more troubling, is that I have a very difficult time getting the oven to come on. I have trouble increasing the temp. The decrease temp. ''pad' seems to work fine if I can get the oven on. Can anyone help? Is it possible to replace this touch pad? Thank you.
  • 163 Answers
You can replace touch pad and not very hard to do,you may want to replace control board also.
Posted on Mar 12, 2009
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven is showing a f1 error
F1
touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
Dec 14, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Turn on power to oven. The upper unit starts on it's own. Can not turn off. Pad reads code F-1.
Hi amarcey,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Dec 06, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
F1 ERROR CODE
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 22, 2010 | Maytag CWG3100A Gas Single Oven
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
The oven touch bottoms are starting to not work acouple at a time do you think the control panel is going or is it the control box be hind it . Model mew5527ddw maytag wall oven
it certainly sounds like it's just the touch pad/membraine that may be going and not the timer/control by your description. does the touch pad visually look worn, i.e.cracking, discolored etc. ? there is a method to check those membranes with an ohm meter and about half a dozen hands, ha ha. (just a side note, on the control where this component plugs in can become contaminated with dirt and grease as well as other debris, at times I've been able to successfully clean the "ribbon connector" with some alcohol and a pencil eraser). but I'd suggest you call a tech if it comes to that.
the panel itself should be part # 5765M482-60. that is again based on info you provided, specifically the model number. also it will likely be packaged indicating it is a "whirlpool" item, don't worry, maytag is now under the whirlpool juggernaut.
hope that helps,
good luck
Sep 28, 2009 | Maytag Ovens
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag oven reads fi
Defective touch pad or clock (ERC)
Jun 01, 2009 | Maytag Ovens
LCD displays trouble code F1. The serial # is MEW6627BAW this is a double wall oven.
HI, this code represents a Defective touch pad or clock (ERC)
May 18, 2009 | Maytag MEW6627B Electric Double Oven
Ovens Logo
462 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
