Question about Honda Landa PG 3500 PSI Pressure Washer
Low pressure in pressure washer - Honda Landa PG 3500 PSI Pressure Washer
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Pressure washer failed
What are the symptoms? Water in oil requires changing seals ( probably high and low pressure) Low , fluctuating pressure is probably valves need cleaning or replacement. Low pressure could also be worn unloader. Water leaking from pump is worn high pressure seals. Many possible failures.
Saying pump has failed is like saying my car does not work.
Feb 10, 2014 | Computers & Internet
How do you get the soap to come out of the C.Haus. pw2200 gas pressure washer
In order for the soap to come out you need to use the pressure washer at low pressure. The injector works on a ventrui system that can only pull chemical at low pressure. Depending on your washer you will either have a black soap nozzle to use or a variable pressure nozzle which you will need to rotate counter clockwise to achieve the lowest pressure possible.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 05, 2011 | Campbell Hausfeld Garden
Low pressure on the pressure washer
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
May 26, 2010 | Karcher 1750 psi Electric Pressure Washer
How do I get my Power Washer to spray with soap in the water?
You will need to adjust the pressure to low pressure by adjusting the lance. This way the machine will draw chemical at low pressure.
May 21, 2010 | Karcher G3025OH Pressure Washer
Low pressure from wand
where do i get a washer for the wand?
May 21, 2010 | Simpson PS2600 PowerShot Commercial-Duty...
My pressure washer wont pump out the cleaning solution i bought it new
Do you have it on low pressure. This is usually done with the nozzle end depending on the model, They only apply soap at low pressure
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Honda Landa PG  3500 PSI Pressure Washer Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
