Question about Gateway GT5056 PC Desktop
Says modem is being blocked
I keep getting modem is being blocked from conncting to the internet
  • Tim Nelson
    Tim Nelson May 11, 2010
    more info on the error would be helpful, does it give an error code? what does it say exactly?
  • 76 Answers
Right click on my computer go to properties and click hardware from there click device manager find it in the listing find the modem and check its properties to see if it was disabled if that doesn't help follow the steps again and delete it and reboot
Posted on Mar 12, 2009
I cannot connect thur my weii. My pc is conncted to the internet and my router is working all right. I have tried disconncting The internet and the router. My weii is on and I entered all of the...
I would first try this. Turn off the modem, router and Wii. After 10 seconds turn on the modem, after another 30 seconds turn on the router and after 30 seconds turn on the Wii. Are you able to connect now?
If not, are you getting an error message?
To hook up the Wii to a router you do so via wireless or via a Wii LAN adapter. I wrote a tech article that goes over how to connect the Wii to the internet. It is fairly brief. I recommend you read the article and check your work. Reconfigure if you have to. Click here for the article.
If you are connecting wireless you have to enter your routers security information into the Wii settings, depending on the setup. The article will go over it.
Let me know if you have any comments. I am here to help.
Regards,
G33k
Jul 06, 2011 | Nintendo Wii Console
How do i get conncted to internet
Well there are two ways to connect, wireless or hardwire. If you do not have a wireless router you need to use a ethernet cable from your modem to connect into the back of your console. If you have a wireless router you can go onto the console and go into settings and go to network settings, depending on if you have a new xbox 360 or a ps3 there is built in wifi, but on older xbox's you need a wireless adapter.
Mar 13, 2011 | Video Game Consoles & Games
My web browser is not working. i cant acces the internet
make sure your ethernet cable (RG45 , looks like , bigger version of telephone cable) is plugged into your (ethernet) port of the computer and the other end of the cabel must be conncted to the modem or router). make sure the router has power and the modem has power, both turned on .
Are the lights on the modem or router lit up ?
the modem must be attached to the router via anolther RG45 ethernet cable. The modem must be conncted to a main signal cable or ethernet jack from your wall outlet or plug
let me know if this helps -- otherwise get in conbtact with your internet service provider
Oct 22, 2010 | Computers & Internet
Everytime i go to get on the internet it knocks me off.
Possible bad modem and or i would remove any and all current Anti Virus spyware progs and install Kaspersky Internet Security 2009 free download also Malwarebytes from Malwarebytes.Org. Do a full scan w/ both of these programs!
Aug 08, 2009 | 2wire (1000-000057-000) Modem
How to install modem to connect internet
GOOD QUESTION.
U WANT TO CONNECT UR NOKIA 6030 TO INTERENT
U HAVE TO CONNCT UR DATA CABLE TO UR PC
AND U HAVE TO INSTALL LATEST MOBI MB FROM C.D. WHICH U GOT WITH UR DATA CABLE
AFTER ALL THIS U CONNECTED UR MOBILE WITH MOBI MB THEN A OPTION WILLBE SHOWN THERE TO CONNECT UR PC FROM INTERNET. IT'S EASY TO CONNECT AND IF U WILL GET A NEW PROBLEM WITH THIS JUST GIVE UR PROBLEM HERE U WILL GET ANSWER.
Apr 25, 2009 | Nokia 6030 Cellular Phone
Can't get on the internet
Have you had Internet connection before this happened? Seems like the connection problem is with your modem. Try this-- Pull the power plug from your modem AND the router. Wait 30 sec. or so and put the power plug back in the modem. Let it go through the self-test phase. (All the lights will stop blinking when complete.) Next, Plug in your router and let it go through the self-test phase. When the router finish, try to connect again.
You may have to double click on your network connection (the 2 pcs in the lower right hand corner) select disable, then enable the connection and try to connect to the internet. If you have any problem, post a comment and we will go from there. Good Luck.
Feb 05, 2009 | Acer Aspire 7720 Notebook PC
GPRS settings for htc3400i with vodafone live
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Feb 02, 2009 | HTC Touch P3450 Smartphone
My psp keeps showing error 80410209 when connecting to the internet
This error means that either the internet signal you are trying to connect to is very weak or not there at all. If you have wifi internet around you it could be that there is a firewall blocking you from using it if it is someone elses wifi and if it is yours your router or modem could be blocking incomming wireless connections. If the second is the problem try restarting your modem or resetting the router to the default setting
Oct 27, 2008 | Video Game Consoles & Games
Can't get internet connection
Check the following
If your link light on the swich port turn green when you connect the Airport to the switch then the connectivity is okey. if not then try connecting the airport with a crossover cable.
If the link is on, then I need the following information. please draw the connectivity and upload and the switch configuration.
Nov 26, 2007 | Cisco Catalyst 3560-24PS Switch
Gateway GT5056 PC Desktop Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
