Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
How much is a craftsman 4200 riding lawnmower worth
6-years old
SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Posted on Apr 06, 2009
panilling9
  • 284 Answers
SOURCE: how do u take off the rear wheel of a craftsman
in the center of each back wheel you see a black cap
this needs to be removed first.
Remove by hand or have pliers that wont damage cap while removing
E clip next it is located behind this cap and needle nose pliers will remove it or a flat blade screwdriver.( could be a bolt if so remove with a wrench that fits turn ccw)
Remove e clip and washer and slide wheel off of shaft along with keystock
Be sure to reinstall keystock in each wheel or your tractor will not move when it is in a gear
if your wheel doesnt come off easy spray the shaft liberally with pb blaster or liquid wrench and let it sit for a few minutes
Find a big hammer and a 2x4 with the rear end jacked up and supported hit on the inside of the wheel (with the hammer hitting the 2x4 )while rotating the wheel to different spots hit with some authority and it should start coming off the shaft
if not heat with a torch is next and rehit some more.
clean and grease shafts lightly before reinstalling for next removal
Posted on Jul 09, 2009
  • 512 Answers
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Posted on Aug 22, 2009
  • 40 Answers
SOURCE: I have an older craftsman GT 18 riding lawnmower
The snowblower attachment manual is available in the manufacturers' website. If not, go to the Murray website. They manufactured these tractors for Sears. You may find the manual there.
Posted on Nov 01, 2009
My serial # is 330702 what year?
  1. what year model is my craftsman riding lawnmower? ' Yahoo Answers
    https://answers.yahoo.com/question/index?qid...May 15, 2009 - However if you are still curious about the year your tractor was built, the month/day/year are the first six digits of the Serial Number; i.e. 051509 ...
Jul 21, 2015 | Garden
How do you replace the large belt on a Craftsman 944.609160, 16 hp, 44" cut
I coulnd not find the owners manual online, however if you can take a pic of the top of the deck I could probably tell you how to string the belt
Aug 29, 2014 | Craftsman Garden
Craftsman riding lawnmower 141/2 model94467042 looking for a manual
www.google.com type in Craftsman 141/2 model or go to this website you will need the model name for it also. Sears, Allis, or Whatever it is?
Sep 19, 2012 | Garden
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Jun 23, 2009 | Craftsman Garden
Trying to find replacement belts for a Craftsman Riding Lawnmower. 6 speed 46'' cut EZ 3 Mulching Family SKH 624U1G2RB Model #CV207 Serial # 2811705321
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=craftsman+rider+belts&_sacat=See-All-Categories
They do have some for your rider here on ebay.
You can also Go to http://www3.sears.com/ Enter your correct model number (the one under the seat; starts with 917) then continue to the diagrams list
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
29 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
