Question about Blomberg Dishwashers
Blomberg dishwasher suddenly has no power,won't turn on
No power to dishwasher
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: My Asko D3121 dishwasher won't turn on. When
Hi.
There is no error code, then check the following:
1)Check that the problem is not overflow.. Remove the lower access panels and check the tray under the dishwasher. If you find it is full of water use a cloth to dry water. Test the overfill switch.
2) Disconnect power, move the appliance forward and check that the drain and inlet hose is OK. Be sure that the machine is filling. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray.
3) Test the door lock. This can be tested jumping its contacts.
4) If all the rest is OK you may have a defective control module. This is not a common fault. Ensure that all the rest is OK first, wiring and pump motor must be tested before going for control module.
Start checking for overfill, that is a very common fault that may cause cycle not starting
If you want to contact a technician use the number listed on the USE AND CARE GUIDE.
Regards.
Ginko.
Posted on Apr 26, 2011
caroldon
  • 17130 Answers
SOURCE: Water won't drain and then dishwasher won't turn on
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Posted on Jul 06, 2012
I have a Blomberg GVN9380 dish washer which is suddenly not working and giving the error 1F. What can we do to fix this please?
Go to repairclinic.com and use the self help section. Enter your model number first to get specific trouble shooting info for your model.
May 13, 2015 | Blomberg Dishwashers
Dishwasher won't start
The technicians data sheet is attached to the bottom of the machine behind the kick panel.
May 21, 2013 | Dishwashers
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
My dishwasher won`t start. NO light are open. The electrical power it's ok.
Jan 27, 2012 | Blomberg DW 15140 Full Console Dishwasher...
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
Dishwashers Logo
220 people viewed this question
Top Blomberg Dishwashers Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
